Strut Replacement suggestions 96 eldo
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, Strut Replacement suggestions 96 eldo in Past Cadillac Vehicle Discussion; The front struts on my 96 Eldo are shot. I am thinking about replacing them with some aftermarket struts, possibly ...
    Newman is offline Cadillac Owners Member
    Automobile(s): Cadillac Eldo and SLS
    Oct 2008
    58
    The front struts on my 96 Eldo are shot. I am thinking about replacing them with some aftermarket struts, possibly just a little bit stiffer. I will probably replace front and back if I change to stiffer struts. Any suggestions, or any brand to avoid. Thanks in advance, you guys are always great help.
    Ian-STS99 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville Limited Edition
    Dec 2008
    225
    Re: Strut Replacement suggestions 96 eldo
    OEM only from what I have found.
    AcDelco part numbers for the front.
    580-106 Left strut
    580-107 Right strut
    Suncore or Arnott might do aftermarket parts, Monroe do not do them.
    Oct 2008
    58
    Thanks for the info. I found a pair at Strutmasters for $397.00. It says it comes with 2 struts and new springs already to bolt on. With directions to disable or bypass the air ride funtion. Of course it would need a front end line up still but I could probably install them myself it appears. Anyone ever used Strutmasters? part # CAD FINSP-EL Thanks, Newman
