Cadillac Forums: front end OVERHAUL - this better fix my baby!
Old 11-06-09, 04:17 AM
Cadillac(s): pearl white '95 Seville STS, crimson pearl '01 Seville STS
View curtc's Photo Album
Casino Cash: $502
So my 2001 STS (186,000k) rides a little rough, seems like she's crashing over some bumps that I never used to feel at all, she was like butta! The front drivers side tire wears out FAST, especially the inner half, and she shakes pretty good down the highway once you hit 65 or so. I've done wheel bearings, a lower ball joint on that side, and outer tie rods before but it never really fixed the problem completely, it only subsided slightly. I recently bought both lower control arms with ball joints, inner and outer tie rods for both sides, and both wheel bearings, new tires too...
Anything else I should look at while I'm under there?
  #2 (permalink)
Old 11-06-09, 06:46 AM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2000
Re: front end OVERHAUL - this better fix my baby!
Struts. If they're original at 186 they must be tired by now.
  #3 (permalink)
Old 11-06-09, 10:25 AM
View Ranger's Photo Album
Casino Cash: $24266
For starters you obviously need an alignment and wheel balance. I would expect worn struts to give a softer ride.
  #4 (permalink)
Old 11-06-09, 12:22 PM
Cadillac(s): STS (99)
View Ian-STS99's Photo Album
Casino Cash: $2965
Change both front struts (left & right) and then have the alignment and wheel balance done.
  #5 (permalink)
Old 11-06-09, 12:32 PM
eyekandyboats.inc's Avatar
Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC
View eyekandyboats.inc's Photo Album
Casino Cash: $16747
road force balance?
  #6 (permalink)
Old 11-06-09, 12:41 PM
Casino Cash: $2965
Originally Posted by eyekandyboats.inc View Post
road force balance?
Yes, on all four wheels.
  #7 (permalink)
Old 11-06-09, 04:21 PM
Casino Cash: $502
I am trying to avoid the struts for the time being, they're a little pricey. I am planning on having a four wheel alignment done as soon as I get done replacing all of these parts, and the tires are balanced just fine, no bent rims or anything like that, I just had this done. If I put my hands on the fenders and make the car go up and down there is absolutely no noise what so ever, the struts seem to be fairly smooth all the way around.
  #8 (permalink)
Old 11-06-09, 05:05 PM
Casino Cash: $2965
You can get direct replacements from Rockauto that sells Monroe shocks / struts that are half the price of OEM shocks.
The direct replacements are the same as the OEM ones (ie active)
186,000k -- the struts are well over due if they are the originals when it left the factory. Get them changed out.
BTW, I've yet to find any other place that makes direct replacements for half the price.
  #9 (permalink)
Old 11-07-09, 03:35 PM
Cadillac(s): 2000 Cadillac STS
View derone's Photo Album
Casino Cash: $2820
Don't forget the sway bar end links...A sawzall comes in real handy when removing the OEM ones.
  #10 (permalink)
Old 11-10-09, 11:07 PM
Casino Cash: $502
Well once I got under there the passenger side was looked and felt pretty good aside from the brake pads. The drivers side wasn't so hot, LCA bushings were shot, ball joint was gone, and so was the outer tie rod end, the bearing went out too due to this. Replaced all of that and had a 4 wheel alignment done and it is much better, but there is still a little shimmy at freeway speed. I can't expect her to ride like she used to after putting over 100,000 on her, not including the 86k she came with, but I'm sure struts are on there way in the near future.
  #11 (permalink)
Old 11-11-09, 03:52 PM
Cadillac(s): 2001 seville sts 170K
View joe45's Photo Album
Casino Cash: $2455
It’s your struts. I just replaced my original OEM ones at 180K with the cheaper passive ones and it rides 90% better do to the lower control arm bushings still needing replacement. My old struts made a lot of noise like something was busted inside of them but they didn’t bounce going down the highway ether.
  #12 (permalink)
Old 11-11-09, 06:27 PM
drewsdeville's Avatar
Cadillac(s): 1995 Sedan Deville-170k miles, 1990 Eldorado- 165k miles
View drewsdeville's Photo Album
Casino Cash: $4065
Keep in mind that, contrary to popular belief, cars do NOT misalign themselves over time for no reason. Unless you have hit a curb or somehow knocked the alignment off by physical force, you probably have worn steering components causing the shimmying. Proper lubrication of the ball joints and tie rod ends will prevent this, but it's probably too late at this point.
You'll want to check your front end components for looseness. If you don't want to do this, don't worry. When you try to get your car aligned, they'll give it right back to you explaining that they won't be able to align it properly due to the problems.
If your struts need changing, don't touch the rest of the car until you are willing to do this. Changing your struts will include aligning the car afterwards. Therefore, it makes no sense to have it aligned now when new struts are on the horizon. Save yourself the extra money and time by doing it all at once.
edit: nevermind, I somehow skipped over your last post where you explain that you had it all done. My bad.
baby, end, fix, front, overhaul
