02 SLS Fuse Box Location
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 02 SLS Fuse Box Location in Past Cadillac Vehicle Discussion; I need to check the fuse for my driver's seat heat. Where is that particular fuse box located? Thanks...
    blackcaddycts's Avatar
    blackcaddycts is offline Cadillac Owners Member
    Automobile(s): 2002 SLS, 2005 CTS Sport & Luxury Pack.
    Mar 2009
    Denver, NC
    54
    34
    Thanks
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    58
    1,693
    Re: 02 SLS Fuse Box Location
    Under the rear seat, passenger side.
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    If the switch light comes on it may not be a fuse issue. The most common failure I've seen posted is the element in the seat breaking.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,184
    If you're talking about the SLS, it's under the rear seat, driver's side. The battery is on the passenger side. Be careful to unplug the heated seat connector on the passenger side, too.
    Turn the key ON. Energize the seat heat and listen down at the lower front of the seat. Do you hear a click every 5 seconds or so ?? That's the circuit breaker in the seat heater module telling you that one of 2 or 3 heater elements is broken. Requires seat disassembly and install a GM-only repair kit, depending on which particular heater setup you have.
  7. Remove Advertisements
