| Re: Need data for 2003 STS heated seat repair Most likely its the heater element in the seat. Use the search feature its been documented many times, but the quick and dirty is that the wire breaks, opening the circuit. Pull the seat cushion out, pull the leather off and you should see a burn mark in the seat padding, dig around a bit and you should find 2 small gauge wires with burnt ends....there is your problem. You can either cut the ends back and solder back together or replace the entire element, you can find the element on gmpartsdirect.com I believe. |
