| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: replacing bose system
11-04-09, 11:44 PM
|  | Cadillac Owners Member Cadillac(s): '92 Seville STS | | | | | replacing bose system my wife is finally letting me ditch the bose system in her 92 seville sts (after the 2nd speaker blew) i just want to check a few things befor i order the headunit and speakers...
i know the stoke bose unit uses an exturnal amp... im wanting to bypass this, so i plan on running all new wire for all 4 speakers... looking online for the wireing harness, the one for the non-bose system looks lik the one for the bose... the bose ones just has rca cables for the amp.... its also like $50 insted of like $8.... since im not wanting to use the amp, could i just get the cheaper one or are the plugs actually different...... im also not wanting to just splice into the factory wireing cus when we sell it, were gonna put the bose back in |
11-05-09, 12:25 AM
| | Cadillac Owners Connoisseur Cadillac(s): 92 eldorado, 97 S.T.S.. | | Join Date: Nov 2005 Location: roberts creek b.c. canada | | | Re: replacing bose system Quote:
Originally Posted by vartok my wife is finally letting me ditch the bose system in her 92 seville sts (after the 2nd speaker blew) i just want to check a few things befor i order the headunit and speakers...
I went through this about 5 years ago with my 92 eldo., I replaced everything,dont try to combine bose with after market components,
it's really not a big job to replace everything,your after market unit should have a built in amp,so forget about the bose altogether,it wouldn't be worth your time to remove new system when you sell the car as an after
market shouldn't cost all that much, you also will need an antenna lead to run from new unit to rear antenna. |
11-05-09, 12:29 AM
| | Cadillac Owners Connoisseur Cadillac(s): 92 eldorado, 97 S.T.S.. | | Join Date: Nov 2005 Location: roberts creek b.c. canada | | | Re: replacing bose system Forgot to say,you dont need a wiring harness as new unit should supply enough wire for the new speakers, you can also buy a new dash adaptor
plate. |
11-05-09, 11:47 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 SLS | | Join Date: Jul 2008 Location: Green Bay, WI Age: 21 | | | Re: replacing bose system You will need to keep the stock unit wired in somewhere in the car, the trunk is a popular place to relocate it to. You will need to do this to keep the theftlock from locking down the car and to keep the chimes. dont buy any special harness that is supposed to take car of those issues, they dont work and cause more headaches. |
11-05-09, 01:42 PM
Originally Posted by mitchjagger You will need to keep the stock unit wired in somewhere in the car, the trunk is a popular place to relocate it to. You will need to do this to keep the theftlock from locking down the car and to keep the chimes. dont buy any special harness that is supposed to take car of those issues, they dont work and cause more headaches. | When I did mine all I did was disconnect old stuff and put in new stuff,
maybe in 92 things were not as involved with the theftlock. |
11-05-09, 01:53 PM
| | Cadillac Owners Member Cadillac(s): 1996 Eldorado ETC Kathy (deceased), 1996 Eldorado ETC Sylvia | | Join Date: Apr 2009 Location: Texas Age: 35 | | | Re: replacing bose system I never had any problems when I replaced mine...96 eldorado. |
11-05-09, 06:13 PM
|  | Cadillac Owners Member Cadillac(s): '92 Seville STS | | | | | Re: replacing bose system i was wanting to get the plug so i didnt have to run a new power, switch power, ground, and ant. cable.... |
11-05-09, 06:22 PM
Originally Posted by vartok i was wanting to get the plug so i didnt have to run a new power, switch power, ground, and ant. cable.... | Believe me you are reading too much into this, you dont need a new power switch,you dont need a special ground,the antenna lead is just an
adaptor that plugs into new unit and runs to existing antenna, it's not the
coax type of wire, I dont know what you mean by a plug, the power switch is the on-off button on the new unit. |
11-05-09, 06:47 PM
|  | Cadillac Owners Member Cadillac(s): '92 Seville STS | | | | | Re: replacing bose system ok... this is what i mean...
non-bose http://www.crutchfield.com/p_1207018...r.html?tp=3486
sorry if thouse dont work right.... im doing this from my phone....
so my question is, is the wireing on those two the same except for the rca plugs? i cant really tell that well from the pics... btw i can get the non-bose one at a local store for way cheaper... just wanna know if it would work
edit: fixed links
11-05-09, 07:10 PM
Originally Posted by vartok | Forget about both of your examples,forget about trying to adapt to the old system, you are putting in a brand new system,your new unit will have all the correct wires on it already. |
11-05-09, 07:15 PM
|  | Cadillac Owners Member Cadillac(s): '92 Seville STS | | | | | Re: replacing bose system ok... then what am i hooking the wire that the headunit comes with, up to? i.e. the two power wires and the ground |
11-05-09, 07:22 PM
Originally Posted by vartok ok... then what am i hooking the wire that the headunit comes with, up to? i.e. the two power wires and the ground | I'm going back 5 years from when I did my first 92 eldo.,when you buy your new unit it will have eight wires for the speakers and one wire for the power,do you have a head unit already with two power wires on it?. |
11-05-09, 07:31 PM
|  | Cadillac Owners Member Cadillac(s): '92 Seville STS | | | | | Re: replacing bose system every headunit ive installed had the 8 wires for speakers, a ground, and main 12v power and a switch 12v power... and a remote wire for either a sub or a power ant. and i kinna need that one to raise the ant. |
11-05-09, 07:38 PM
Originally Posted by vartok every headunit ive installed had the 8 wires for speakers, a ground, and main 12v power and a switch 12v power... and a remote wire for either a sub or a power ant. and i kinna need that one to raise the ant. |
Sorry, all I can tell you is what I did, and it worked,I never gave any thought to the power antenna and it worked, every thing worked. |
11-05-09, 07:40 PM
|  | Cadillac Owners Member Cadillac(s): '92 Seville STS | | | | | Re: replacing bose system ok, what did you connect the power to? | | Cadillac Discussion Tools | | |
Censor is ON | | | |
