struts
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, struts in Past Cadillac Vehicle Discussion; Have a rattling coming from the front end when i go over bumps is this a sign of bad struts ...
    dglad's Avatar
    dglad is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    46
    30
    struts
    Have a rattling coming from the front end when i go over bumps is this a sign of bad struts its pretty irritating.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: struts
    I think it's more likely sway bar links.
    69
    82,159
    Re: struts
    Or sway bar bushings.
    dglad's Avatar
    Sep 2008
    46
    30
    Re: struts
    I put the car up on ramps and i can wiggle the end links and i think i hear the same noise just not as bad as when i hit bumps but i also think the struts may be bad because if im on the highway and go over a bypass the front end will bounce for a bit.
    joe45's Avatar
    joe45 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 seville sts 219K
    Feb 2009
    156
    Re: struts
    My STS had 180K on the original struts and they made some noise. I replaced the sway bar links first (made no difference) then the struts (made some difference) then I tried the lower control arm bushings but the ones I ordered didn’t fit. Does anyone know where to get aftermarket lower control arm bushing kit for a 01 STS? Don’t buy this one it doesn’t fit. http://www.performancesuspension.com...roducts_id=621
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,568
    Re: struts
    Call Luke in Parts at Lindsay Cadillac over there >>>>>>>>> M-F, 9-5 EST. If anyone makes performance bushings he will know that, too.
    joe45's Avatar
    Feb 2009
    156
    Re: struts
    They don't have to be performance just a standard bushing will work for me. That kit I ordered looked like the rear ones would fit but the front ones where over 10mm to small.
    Feb 2006
    56,568
    Re: struts
    Luke can give you the straight dope, they ship all over the world, and they offer online parts discounts.
    dglad's Avatar
    Sep 2008
    46
    30
    Re: struts
    I was looking under my hood today and noticed that the engine mounts up front are both shot so that could be the noise im hearing ordered new ones will post when i get them on.
  12. Remove Advertisements
