98 Seville STS, help please
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, 98 Seville STS, help please in Past Cadillac Vehicle Discussion; Hi, For some reason I cannot get any heat from the heater, it only blows cold. I can hear the ...
    Roosterace is offline Cadillac Owners Member
    Automobile(s): 1998 STS Seville (RHD)
    Feb 2009
    Nottingham, England
    66
    36
    Hi,
    I can hear the controls working the baffles, but no heat !!
    With the coming of winter I would really welcome any advice please.
    many thanks
    Red
    Pete315 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Feb 2009
    305
    Re: 98 Seville STS, help please
    air pocket in engine. head gaskets are bad. welcome to the club.
    Feb 2009
    Nottingham, England
    66
    36
    I don't think its that, I've had the head gaskets changed, and I'm getting no symptoms of head gaskets problems as I had before.
    I've just checked the heater hoses and one's hot the others cold, this may point to a valve or something?
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Quote Originally Posted by Roosterace View Post
    That points more towards a clogged heater core. That happened to me too. I unhooked the hoses in an accessible place and blasted a garden hose through it in both directions. A bunch of crap came out and the heat worked fine ever since. Try that.
    69
    82,188
    First be sure that the purge line is clear and flows coolant. If that is OK, then flush the core. Was the block Timeserted when the gaskets where changed?
    Feb 2009
    Nottingham, England
    66
    36
    Quote Originally Posted by TimmyC View Post
    Thanks,much appreciated.
    Feb 2009
    Nottingham, England
    66
    36
    Sorry, but but you lost me on the first count, where and how do I check the purge line?
    The gaskets where changed by a Caddy dealer, so I don't know about Timeserted, or even what it means, sorry !!
    Sincere thanks for your help though.
    Red
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    59
    1,693
    The purge line is the 5/16" rubber line that runs from a nipple on the waterpump housing to the top of the surge tank, on my 97 it runs under the beauty cover since my surge tank is on the opposite side of the engine from the waterpump, not sure where a 98 surge tank is located. The line purges air from the waterpump so it doesn't become airbound. With the engine cool, pull the hose off the fitting on the surge tank and stick it in the open top of the surge tank, then start the car and observe the flow of water. You should have a pretty solid stream of water and the volume will increase as the engine speed increases. If you don't have a good stream of water then the line is probably clogged at the fitting on the water pump end of the line. Pull the rubber line off that fitting and claen out the inside of the fitting with a small nail or some weedwacker string. You will need to get into the fitting about 2" to get to the main water passage. After that put the line back on at that end and try it again. Once you get water flowing out the other end, hook that end back to the surge tank.
    69
    82,188
    The purge line is the 3/8 " line that runs from the water pump to the side of the surge tank (near the top). Pull the line (engine cold) and stick it in the surge tank. Have someone start the car and watch for flow. If not, locate and clear the restriction.
    EDIT: Oops, looks like I was too slow.
    Feb 2009
    Nottingham, England
    66
    36
    Thanks Mark & Ranger, yes, I know exactly what you mean now.
    sincere thanks to both.
    Red
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    If one hose is hot and the other not I'd suspect a problem in the heater core. There is no valve.
  14. Remove Advertisements
