Cadillac Forums: Driver’s side window switches - Need Help
Old 11-02-09, 02:35 PM
Cadillac(s): Cadillac Eldorado
View midnightrider's Photo Album
Casino Cash: $1165
Hello everyone. I need some help in regards to my driver’s side window switches. Are they suppose to light up? Mine do not but it looks like they should.
I did a search on the web-site but I could not find anything on this subject.
My car is a 2000 Eldorado ESC. The passenger side lights up just fine.
  #2 (permalink)
Old 11-02-09, 02:54 PM
Cadillac(s): 2000 Eldorado ETC
View Carvone's Photo Album
Casino Cash: $1775
Re: Driver’s side window switches - Need Help
Both switches should light up in the little white area at the bottom of the switch, probably have a burned out bulb.
  #3 (permalink)
Old 11-02-09, 09:55 PM
Casino Cash: $1165
That's what I thought. Does anyone know how to change it?
  #4 (permalink)
Old 11-02-09, 10:28 PM
N*Caddy's Avatar
Cadillac(s): 1997 Cadillac STS
View N*Caddy's Photo Album
Casino Cash: $11575
Unfortunately the switch is NOT serviceable (at least at the point of replacing the light bulb. Test first if you have power to the connector (common issue bad contacts in the connectors).
  #5 (permalink)
Old 11-02-09, 11:03 PM
Casino Cash: $1165
Hey N*Caddy, how do I gain access to the switch?
  #6 (permalink)
Old 11-02-09, 11:15 PM
N*Caddy's Avatar
Casino Cash: $11575
First remove the bezel around the door handle (is not absolutely necessarily but is easy to remove and it helps).
Then using a plastic flat tool (metal scratches), pull the rear of the switch assembly as forward as you can and then lift it. There is a spring-loaded clip that locks the switch in place. You should be able to do-it with bare hands garbing the back edge of the switch assembly and pulling forward and UP.
  #7 (permalink)
Old 11-03-09, 04:26 PM
Cadillac(s): 2000 SLS
View Eric's Photo Album
Casino Cash: $5869
See last post at:http://caddyinfo.ipbhost.com/index.p...844&hl=2721154 for how to replace bulb.
  #8 (permalink)
Old 11-03-09, 08:58 PM
N*Caddy's Avatar
Casino Cash: $11575
Unfortunately that is a 2002 STS and completely different switch assembly.
The heated seats buttons and track and PRND321 lights are indeed serviceable (actually heated seats not, that would classify as a switch rebuild).
Here is my interior (all replaced with white LED).
driver’s, side, switches, window
