Cadillac Forums: 2000 Seville northstar cyl 4 misfire
Old 10-28-09, 01:38 PM
Cadillac(s): Cadillac
View don0102's Photo Album
Casino Cash: $285
Oil in plugs. replaced plugs valve covers and both coil packs. Engine cover gaskets also replaced. Misfire comes back within 10 miles gradually. Diagnostics done at shop compression is good, injectors are good. Cylinder 4 is the one continuosly misfiring.
Will appreciate relevant help. Please advise if I can conduct any tests to pin point the problem.
Please also point out any possible causes.
  #2 (permalink)
Old 10-28-09, 05:15 PM
View Ranger's Photo Album
Casino Cash: $24291
Re: 2000 Seville northstar cyl 4 misfire
What did the tip of that #4 plug look like? Any different from the rest?
  #3 (permalink)
Old 10-29-09, 10:42 AM
Cadillac(s): 2000 Cadillac STS
View derone's Photo Album
Casino Cash: $2820
You can test the coil 'cassette' by swapping them, front and rear, and see if the problem follows the suspected bad one.
  #4 (permalink)
Old 11-02-09, 08:44 PM
Casino Cash: $285
Yes. They were also switched around. One at the time was bad and got replaced. Ran the test later. Both cassettes good still cyl 4 misfire
  #5 (permalink)
Old 11-02-09, 08:48 PM
Casino Cash: $285
2 different mechanics told me that there was oil in more than 1 plugs. They both replaced all. While hooked to diagnostics computer I saw myself that there is slight misfire in cyl 1 but not as bad as 4 at a point when it stopped firing at all. To answer it, I did not see if the oil was sitting on tip or around.
What do advise next ?
  #6 (permalink)
Old 11-02-09, 09:47 PM
Casino Cash: $24291
If you are talking about oil down in the plug well, that is somewhat normal. just a little seepage form the cam cover O rings.
Get a stethoscope or piece of hose and listen to #4 injector. Does it have a rhythmic tic tic like the others?
  #7 (permalink)
Old 11-05-09, 12:33 AM
johnny kannapo's Avatar
Cadillac(s): 1996 eldorado
View johnny kannapo's Photo Album
Casino Cash: $425
Its called carbon tracking. moisture, water or oil in the plug boot has caused the spark to track down the porcelin to ground out leaving a black carbon track that you can see on the porcelin. The same carbon track is tracking down the inside of the wire boot and will be visible as a gray track. if you use the same contaminated plug wire boot it will quickly find a path down the inside of the boot to ground out. The plug porcelin can be cleaned but the boot is tatooed with a carbon track burned in and has to be replaced.
  #8 (permalink)
Old 11-05-09, 08:27 AM
kckranz's Avatar
Cadillac(s): 2000 Seville STS, 2005 Nissan Pathfinder
View kckranz's Photo Album
Casino Cash: $3225
don0102 - What kind of plugs were you using and what were they replaced with?
  #9 (permalink)
Old 11-05-09, 09:40 AM
submariner409's Avatar
Casino Cash: $20744
The plugs needed are ACDelco #41-987, pregapped to .050". Use 13 ft/lb of torque and maybe a tiny dab of anti-seize on the first 4 threads. Get a new set of plug boots while you're at it...........www.rockauto.com
johnny kannapo is exactly correct. Those plug boots will carbon track just like an old distributor cap and cause a nagging miss that's a bear to track down.
  #10 (permalink)
Old 11-13-09, 01:40 PM
Casino Cash: $285
Great advice indeed. So it's the grounding through that causes this. How do I take care of the oil in plugs so it won't provide a ground again ?
Plugs replaced were Bosch platinum. The other times don't know, really at the mercy of mechanics.
Please advise
  #11 (permalink)
Old 11-13-09, 04:22 PM
Casino Cash: $20744
Oil does not cause grounding: oil is an insulator, as in: PCB-based oils used inside transformers. Don't worry about a bit of oil in the plug wells - it harms nothing.
The ground is actually a "carbon track" created when the high voltage takes a path of least resistance in the plug-boot assembly - the spark which runs down the outside of the plug insulator actually carbonizes the plug boot in a hairline and creates a very effective ground wire. Same principle as carbon tracking the inside of a distributor cap between the plug contact posts.
If you cannot track down the miss outside of the coil cassette, then you may have to go back to square 1 and change to the recommended ACDelco plugs, a couple of posts back, and replace the plug boots also.
  #12 (permalink)
Old 11-14-09, 06:49 AM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2025
N* hates Bosch plugs. I used them in my 4.5 CDV and they were fine. After 10,000 miles in my STS they were burned out carboned up junk. Switch back to AC Delco when you change the boots.
2000, cyl, misfire, northstar, seville
