Cadillac Forums: 2004 SLS Ext. Warranty about to Expire
Old 10-17-09, 08:29 PM
Cadillac(s): Cadillac Seville SLS 2004
View gerrysatx's Photo Album
Casino Cash: $675
My extended warranty is about to expire in a couple of weeks. Anything I should look for to report to the dealer. Any suggestions would be appreciated. Besides a trim replacement and a stuck console door, not much has gone wrong. Thanks.
  #2 (permalink)
Old 10-17-09, 08:34 PM
View Ranger's Photo Album
Casino Cash: $24216
Re: 2004 SLS Ext. Warranty about to Expire
Front motor mount.
  #3 (permalink)
Old 10-17-09, 08:38 PM
ryannel2003's Avatar
Cadillac(s): 2000 Seville STS (Sterling)
View ryannel2003's Photo Album
Casino Cash: $16470
Oh check for warped dashpads - they are extremely common on Seville and expensive to replace (about $600). Tend to warp around the windshield and in front of the glovebox. Run through your codes (look at top of page to learn about how to pull) and see if you see anything that is Current.
Ranger is right about motor mount; also check for trunk leaks.
  #4 (permalink)
Old 10-17-09, 09:08 PM
Casino Cash: $675
Ranger and Ryan:
Thanks for the suggestions, you guys just saved me a ton. As soon as I read your posts, of course, ran to check things out. First, the motor mounts -- now I now what that shift thunk is that I've been hearing/feeling. It's gotta be a broken mount.
I checked the front dash pad, and sure enough -- it's warping -- I had missed it, but it's really obvious now cause when I press it down it gives about an inch and springs right back up.
I need to really go over the whole car and check it out closely. BTW, I haven't noticed any leaking in the trunk, but will spray hose it and then check it.
I'll update and see how that goes and if I find anything else out.
edit--I'll check out the codes as well.
Last edited by gerrysatx; 10-17-09 at 09:09 PM. Reason: Add additional information.
  #5 (permalink)
Old 10-17-09, 09:14 PM
Casino Cash: $24216
Check the struts. I got one replaced a few months ago, just before my warranty expired. Jack up each side so the wheel hangs. Then lift the corrugated boot so you can see the strut shaft. If there is any oil on the strut top, it should be replaced. Mine did not even have enough to drip down the side.
  #6 (permalink)
Old 10-19-09, 09:14 AM
Cadillac(s): 2003Cadillac Seville STS
View finerwoodworking's Photo Album
Casino Cash: $2520
Front wheel bearings. I had to replace mine at around 50k.
  #7 (permalink)
Old 10-22-09, 10:28 PM
Casino Cash: $675
OK. Here's an update.
Ran the hose under pressure around the trunk and no leaks.
Took the car in and they replaced the whole driver seat pocket in back as some rear passenger pulled on the pocket when trying to exit and broke one of the pins. They were never able to fix it right so the dealer ordered the whole seat pocket and replaced it.
Asked my rep to check car over especially struts....reported that struts are good and not leaking, but were replacing the rear shocks (warranty work).
They've ordered a new dash pad due to the warping (also warranty).
I'll call my rep tomorrow about the front wheel bearings.
Thanks again all....and will update later.
2004, expire, ext, sls, warranty
