Originally Posted by masterzelda ... I also discovered that it is getting very poor oil pressure as well... |
That's probably the cause for most of your noises. If the hydrolic lifters don't get enough oil pressure, they will make noise. Plus the friction bearings need good oil pressure. Fix the oil pressure issue first.
The screeching/scraping you describe sounds more like a bad serpentine belt or something.
To determine whether the headgaskets are bad, get the coolant tested for exhaust gas byproducts.
Originally Posted by SPreston2001 ...The good thing about this whole situation is that im killing two birds with one stone since they have to timesert the block when they put everything back together so I should be headgasket worry free lol... |
Timeserts have a pretty high failure rate, which is why many dealerships refuse to install timeserts anymore. Instead they choose to only install factory rebuilt engines.
If I were you I'd see if I could get them to stud the block instead.
http://www.cadillacforums.com/forums...t-inserts.html (Northstar Repair without inserts) http://www.northstarperformance.com/
