Cadillac Forums: 2000 Eldo Esc bad gas mileage
Old 10-08-09, 10:48 PM
debar252's Avatar
Cadillac(s): eldorado
View debar252's Photo Album
Casino Cash: $335
hey i have a 2000 eldo i got it about 3 months ago gas mileage was goin good just until recently any ideas i am down to about 10mpg
  #2 (permalink)
Old 10-08-09, 10:51 PM
View Ranger's Photo Album
Casino Cash: $24241
Re: 2000 Eldo Esc bad gas mileage
A leaky FPR is a common cause. Easy to check. See the Tech Tips section.
  #3 (permalink)
Old 10-08-09, 11:27 PM
debar252's Avatar
Casino Cash: $335
Hey i looked in the tech tips if u happen to have the link could u please send it to me
  #4 (permalink)
Old 10-08-09, 11:38 PM
Casino Cash: $24241
Page 2, 3rd from the bottom.
  #5 (permalink)
Old 10-08-09, 11:47 PM
debar252's Avatar
Casino Cash: $335
hey do u have the link 4 that i cacnt seem to find it
  #6 (permalink)
Old 10-08-09, 11:52 PM
Casino Cash: $24241
http://www.cadillacforums.com/forums...-pressure.html (How to check for a faulty FPR (Fuel Pressure Regulator) and replace it)
  #7 (permalink)
Old 10-09-09, 12:01 AM
debar252's Avatar
Casino Cash: $335
alright i had read ur instructions but when u say turn the key on but dont turn the key on do u want me to crank it or just set it to accesory
  #8 (permalink)
Old 10-09-09, 11:21 AM
submariner409's Avatar
Casino Cash: $20694
The key has 4 positions: OFF, ACC, ON, and (spring loaded) START. You can turn the key to the ON (run) position but do not continue past that to START. When the Key is first turned to ON the fuel pump runs for 3 seconds to pressurize the fuel system.
Your Fuel Pressure Regulator is in the fuel rail on the rear right end - a dome-top small metal can held in the fuel rail by a hairpin clip. On the top is a vacuum connector which comes from the throttlebody casting. Remove the vacuum connector from the FPR nipple and have an assistant turn the key ON while you watch the FPR. Does any fuel come out of the FPR metal nipple ?? Now START the engine while plugging the vacuum line with your finger and watch the FPR nipple. Does fuel weep or spray out ??
If the FPR leaks, replace it. www.rockauto.com. "fuel/air", "fuel injection pressure regulator". Smear a drop of engine oil on the O-rings and make sure the small bottom O-ring slides down into the fuel rail fitting.
Another cause of low fuel mileage is a dirty air filter. Check yours and if you can't see light through it when you hold it up to the sun, replace the filter. Careful: do not damage the MAF (Mass Airflow Sensor).
You need a GM/Helm Factory Service Manual - either from eBay or www.helminc.com or subscribe your car to www.alldatadiy.com
  #9 (permalink)
Old 10-09-09, 01:03 PM
Casino Cash: $24241
On any Northstar except the '93/'94 you can check it key on/engine off or at idle.
Tags: ,
2000, bad, eldo, esc, gas, mileage
