| Re: Help Changing Refrigerant On 97 Seville STS I'm not familiar with that brand but if it contains a sealant take it back to the store. Instead of those bottles that come with the hose and connector attached, just get a plain ole' can of 134a ($7) - it is OK to get one with a leak detector and perhaps this is a good idea. Somewhere near the cans of refrigerant, in the parts store, there will be a 12 - 16 inch hose sold separately ($6). This is what is used to transfer the refrigerant from the can to the A/C system.
So you've got the can and the transfer hose. Guess which end of the hose screws into the can? You can't get it wrong. The hose-end that connects to the can has a valve on it.
*****You will need to re-enable the a/c compressor before continuing - others will chime in to help me here or you can search for a "how-to" (it's been covered before)*****
Start the car and set your climate control to the lowest temp and highest fan setting (override the "auto" feature). Pop the hood and locate the "low-side" A/C service port with the black cap. Unscrew the cap and attach the other end of your hose to it. It will be obvious if it doesn't fit - don't force it in this case - you've got the wrong port!
Unscrew the valve (puncture the can) and the refrigerant will flow (the can will get very cold). I have read and always say to fill the system with the can upright - the system will only "take" what is needed and the risk of overcharge is small. Others with plenty of credentials will say to turn the can inverted to chug the refrigerant in (much faster but more risk of overcharge). Either way, hold the can tight in your warm hands to keep the refrigerant moving.
Test for cold air from the system. Close the valve and disconnect from the service port. If you used 134a with leak detection you may wish to inspect the system after several days / weeks and look for any green fluid from a/c components / fittings.
