- 08-01-09 05:02 AM #1
Banned
Cadillac(s) I Drive: 2000 Seville STS
- Join Date
- Jan 2009
- Age
- 27
- Posts
- 468
Can plugging intake resonator cause problems?
I am considering plugging my intake resonator on my 2000 STS to make it easier to check my tranny fluid and air filter. Can this cause any problems whatsoever? I dont forsee any, but with all the damn sensors on these cars I always worry I am going to throw something off.....????
Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.- Join Date
- Always
- Age
- 2010
- Posts
- Many
- 08-01-09 09:43 AM #2
Cadillac(s) I Drive: White Diamond '03 DHS
- Join Date
- Jun 2004
- Location
- Woodstock Ill.
- Age
- 62
- Posts
- 39,465
Re: Can plugging intake resonator cause problems?
No. All it does is reduce the intake noise. Have at it.
- 08-01-09 12:33 PM #3
All been done before.......many posts here and Northstar Performance.
- 08-02-09 09:46 AM #4
Why do you have the clamp on the PCM cover, Sub?
- 08-02-09 10:19 AM #5
That corner of the cover was slightly warped, so I was trying to coax it back into place. Finally took 2 flat black hex head STSM screws and, using 2 different sized drill holes, make hold-downs for the corners. Did it when I did the side-hole airbox mod - just on the dirty side of the filter the side of the airbox is cut out and mated to the existing hole in the inner fender sheet metal with a cut foam gasket. Essentially doubles the size of the outside air intake area. These things are already a good CAI, so the trick is to get a bit less restriction in the box while looking stock.
(I am a firm believer in the little saying just under my login ^^^ )
| Sponsored Cadillac Advertisements (Supporting Members don't see these ads): | |
LinkBack URL
About LinkBacks
