Originally Posted by Ranger I think that plastic sheath might have a steel liner. |
Ok. That makes sense. I guess about all I can do is try to work it back and forth. Maybe it'll free up.
Originally Posted by Ranger The piston has to extend, just like the front caliper, but unlike the front, you screw it in as opposed to compressing it with a C clamp. |
You gotta be pullin' my leg, Ranger! You're really throwing me for a loop here. FSM 5-102 says compress with a C-clamp; nothing about any screw action. Are you telling me the book is just whacked?! The piston is barely visible, let alone accessible. How could it be rotated in the cylinder by a service person? And during operation the friction of the lip of the piston against the back of the brake pad would be ridiculous, it seems.
Unless...it only works like a screw when it's mechanically operated in park brake mode. Then when the park brake is released it operates in normal hydraulic piston mode. So as long as that hefty little coil spring mounted on the caliper housing is un-sprung it should be in piston mode, if it's not been damaged? I'm still not so sure that makes much sense to me. I mean, why not just push on the piston mechanically in park brake mode? What's the point in rotating the piston? But I really hate the idea that the book is full of crap!
Can you help me out here, Ranger?
