Hello, my passenger side window started malfunctioning. I took apart the door panel to see what was going on and this is what I found:
1. The cable was all tangled up inside the area with the blue wheel at the regulator/motor.
2. One of the shitty plastic wheels had fallen apart.
So does anyone know if i can get those white plastic wheels separately? If I can't, what do I need to buy in order to repair it? Also, if I buy a "window motor" like this one,
http://www.autopartsfair.com/cadilla...s-b468707.html does the blue wheel on the other side come with it?
Pretty much the same thing that happened to me happened with this guy except I need both a new cable assembly and at least one replacement white plastic wheel.
http://www.cadillacforums.com/forums...regulator.html (Front passenger window regulator)
Does anyone know where I can get the cable assembly for the left front passenger window of a 1999 seville?
Thanks
