Blown HG?
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Blown HG? in Past Cadillac Vehicle Discussion; I have oil in my coolant and coolant in my oil... i can still drive it and it drives fine ...
    Guerilla is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville
    Dec 2008
    25
    7
    Blown HG?
    I have oil in my coolant and coolant in my oil... i can still drive it and it drives fine except for a few noises... could it be the Head Gasket or something else?
    MrEldo97 is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Eldorado
    Jun 2009
    65
    136
    Re: Blown HG?
    Have it checked for exhaust gas in the coolant. If present you have pulled head bolts.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,143
    Re: Blown HG?
    Depending on what car year, model, and RPO you own, you might have a leaking engine oil cooler or transmission fluid cooler. That is a more common failure which puts oil in coolant or vice versa. The head gasket problem generally causes coolant loss due to overpressure in the system caused by exhaust gas blowing into the coolant.
    The exhaust gas test measures gasses in the airspace over the coolant in the surge tank, not the coolant itself.
    69
    82,383
    Re: Blown HG?
    DO NOT drive it with coolant in the oil. Bearings and coolant do not play well together.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Re: Blown HG?
    Listen to Sub and Ranger - both excellent replies
  8. Remove Advertisements
