left turn signal
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, left turn signal in Past Cadillac Vehicle Discussion; Left turn signal works fine for the first 20 minutes I drive then quits. Any solutions I appreciate. Jim...
    reality1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    10
    left turn signal
    Jim
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,374
    Re: left turn signal
    What year Seville or Eldo? Could be the cam going out.
    Feb 2003
    california
    69
    6,663
    So you're the guy that leaves his signal on for 20 min!!! Seriously, we need more info. When it doesnt work does the left arrow stay on steady on the dash? if so, suspect the flasher, or a front or rear left side bulb socket. Put on the 4 way flasher and walk around the car to compare left to right side for correct bulbs coming on. report back
    Jan 2007
    10
    Quote Originally Posted by Jesda View Post
    I apologize....it is a 01 Seville SLS
    Left turn signal works fine through 20 minutes of normal city driving, then will just show a steady light on dash.
    It has done this every day for a month.
    Jan 2007
    10
    I tried the flashers...work good, then turn signal started working again after I turned the flashers on and off.
    kckranz's Avatar
    kckranz is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville Base, 2004 Escalade AWD
    Dec 2008
    Raleigh, NC
    42
    275
    Quote Originally Posted by reality1 View Post
    Jim
    Keep your commutes under 40 minutes and leave 20 minutes earlier.
    Don't think about it. It doesn't mean anything.
    Feb 2003
    california
    69
    6,663
    By "tried flashers" do you mean the 4 ways and everything lit up ok? if so, swap the 4 way flasher for the regular flasher. 4 way flashers are more heavy duty units. and report back. Another thing to do, is when the light stays on steady, get out and look at the front and rear and make sure all lamps are lit and at full brightness. A corroded socket can cause this and be time or heat senitive.
  10. Remove Advertisements
