Is battery Bad??
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Is battery Bad?? in Past Cadillac Vehicle Discussion; ...
    29Roadster is offline Cadillac Owners Member
    Automobile(s): 1994 Eldorado STC
    Dec 2008
    San Francisco Bay Area
    61
    17
    Is battery Bad??
    About 6 months ago when I tried to start the car, all I got was a clicking sound, but I was able to jump start it and get on my why. When I got home I pulled the battery cables and found a small amount of corrosion so I cleaned the cables and it worked fine until yesterday. I had driven the car around town all day, but later in the evening when I tried to start the engine all I got was clicking again.
    Could the battery be worn and require replacement, I believe it’s about 2 years old (AC Delco) or could the problem be somewhere else? Hopefully not he starter.
    SPreston2001's Avatar
    SPreston2001 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Polo Green Metallic Cadillac STS 60K
    Dec 2008
    Columbus, OH
    34
    787
    Re: Is battery Bad??
    Nope its your battery. Take it to autozone and have them test it to confirm.
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    You may want to let us know what kind of car you have and how old it is. We can not read minds.
    With that being said, your charging system may be on its way out depending on how old your alternator is. Check the easy things first, including all connections to and from the alt, the fuse block and the battery.
    69
    82,372
    Assuming that this is a Cadillac, there is a battery voltage reading in the DIC.
    Dec 2008
    61
    17
    Quote Originally Posted by Playdrv4me View Post
    Whoops.
    It's a 1994 Eldorado STC w/68,000 miles.
    greg-sls's Avatar
    greg-sls is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 SLS
    Jun 2007
    Phoenix
    550
    Toggle the info button to get volts displayed. Then turn the key to "on" but do not start. Get that reading. Next, start the car and get reading after it's running (turn off A/C to be fair to the test). If the first reading is under 12 volts, the battery could be dying. If the second reading is under 13 volts, it could be an alternator. When you cleaned the battery terminals, some model's positive lugs are in 2 segments - did you clean between them?
    69
    82,372
    I'm not sure how well that thing works, but if you can, get a reading while cranking as well. If not, watch the headlights while cranking. If the voltage drops real low or the headlights go real dim, the battery is shot.
    Dec 2008
    61
    17
    Problem solved with a $2 part.
    Once I disconnected the battery cables I discovered the bolt (don't know the official name) that holds down the negative cable had stripped threads.
    That's the least expensive repair I've ever made on this car.
    Thanks All,
    Rick
  11. Remove Advertisements
