2 more problems/questions, one about remote, one about tire caps
Results 1 to 10 of 10
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2 more problems/questions, one about remote, one about tire caps in Past Cadillac Vehicle Discussion; The remote keyfob that came with my car does not work. I took it to a dealer to have it ...
    Dudley Dawson is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Eldorado
    Jun 2009
    32
    101
    The remote keyfob that came with my car does not work. I took it to a dealer to have it tested, and it needs to be replaced. What is the cheapest/best way to go about replacing that (where should I order it from, can I program it myself? etc..)?
    The cap on one of my tires will not come off so I can't check pressure. I took it to Discount Tire and the dealership who both told me it needs to be cracked and replaced. Discount Tire told me this is a common problem with Cadillacs and their chrome caps. Is there another way I can try and get the cap off without shelling out 80 bucks?
    Thank you for your help everybody!
    STSS is offline Cadillac Owners Enthusiast
    Automobile(s): '03 STS 122K, '01 STS 161K - 3/3/11
    Apr 2008
    Grafton, Ohio
    32
    671
    Re: 2 more problems/questions, one about remote, one about tire caps
    Order your fob off ebay. Dealer only for programming.
    I've never had an issue with my valve stem caps, are you sure they're OEM? I know some fancy aftermarket chrome caps have a locking mechanism built in so people cant steal them.
    Jun 2009
    32
    101
    I am pretty sure they are OEM, they come off easily on my other tires.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,179
    Wrap a rag around the valve stem and give the cap/threads a squirt of PB Blaster (penetrant) and let it sit for an hour or so.
    68
    82,048
    A pair of pliers should get it off.
    Jun 2009
    32
    101
    ^ tried that, won't budge
    I'll give the PB Blaster a shot.
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    I've had that issue before. The shop said they can literally "seize" onto the valve stem and can be damn near impossible to get off. I don't know how much of that is just an attempt to sell a tire, but in the last case I had the car wasn't in for tires at all. The dealer was just doing a courtesy air check after having other work done.
    Try Sub's advice on penetrant.
    Feb 2006
    56,179
    If you are careful with 2 pair of slip-joint pliers you can grab the part of the valve stem just at the brass threaded portion - there's some of that brass barrel down in the rubber - and grab the cap - and carefully twist so as not to stress the valve stem rubber.
    Jun 2009
    32
    101
    Another question:
    Is buying a blank vat ignition key off ebay a good idea? I need a spare key as well and am looking to save money of course.
    SPreston2001's Avatar
    SPreston2001 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Polo Green Metallic Cadillac STS 60K
    Dec 2008
    Columbus, OH
    33
    787
    Yeah I brought two off of Ebay and they work perfectly. If programming is the same for your Eldo as it was for my STS then it is definetely worth it. Had the keys cut at my local hardware store for $1 and programming the keys takes every bit of 20 secs. Dont waste your money at the stealership for something you can get for less than $10.
  13. Remove Advertisements
