Results 1 to 3 of 3
Thread: Service Emission System 96 Eldorado
    RoyalCaddy1's Avatar
    RoyalCaddy1 is offline Cadillac Owners Member
    Automobile(s): 1996 Cadillac Eldorado ETC
    Jun 2009
    Bloomington, IL
    40
    66
    I was returning home from a long trip (over 1,200 miles) and my SERVICE EMISSION SYSTEM light came on. My exhaust has been loud since I bought the car 2 months ago, but this is the first time any emission message has come on. Does this usually mean the catalytic converter is bad?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Re: Service Emission System 96 Eldorado
    Take a look at the sticky thread at the top of the main Seville page titled "How to pull codes". You want the link for OBD-I (OnBoard Diagnostics I) - it has an "obd1" in the URL. Learn to read your codes from the car's built-in system. You don't need a scanner. If the cat or O2 sensor system is bad there will be letter-number codes set which can be deciphered using the directions in the link.
    Jun 2009
    Bloomington, IL
    40
    66
    The only current code is PC0420 which is for low catalyst efficiency so I believe the cat converter may be bad. It also sounds like the loud noise in the exhaust is coming from that area.
  • You may not post replies
