Coolant level
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Cadillac Seville / Cadillac Eldorado Forum Discussion, Coolant level in Past Cadillac Vehicle Discussion; My '98 Eldo finally goes to the mechanic this morning. He got a tester from NAPA and will check the ...
    Mitch3 is offline Cadillac Owners Fanatic
    Automobile(s): 98 Eldorado
    Apr 2004
    Albany, New York
    78
    214
    Coolant level
    My '98 Eldo finally goes to the mechanic this morning. He got a tester from NAPA and will check the coolant. Also running a leak test and few other things. I'm hoping for the best but trying not to think of the worst (HG). Here's something strange... I checked the coolant first thing in the a.m. before starting the engine and the level was right up there. After running the car around town, I let it cool down a bit and checked the level again. It was down to the bottom of the surge tank. There was still some pressure in the tank when I removed the cap. Is it normal for the tank to be full when it is totally cold ???
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    Re: Coolant level
    The coolant level, cold, is halfway up the tank. Warm or hot, (be careful) there should be considerable pressure in the tank/system - depending in which cap you have, 16 or 18 pounds. The pressure builds from the coolant expansion as the engine heats and is one of the factors which raise the boiling point of 50/50 coolant to 265 degrees. The airspace in the tank is necessary to prevent expanding coolant from blowing out of the cap relief.
    69
    82,162
    Re: Coolant level
    Quote Originally Posted by Mitch3 View Post
    Mitch, can you define "Right up there" and "Full"?
    Apr 2004
    Albany, New York
    78
    214
    Re: Coolant level
    So what you are saying is when it's warm (or hot) the level should be higher than when it's totally cold. Mine is much lower hot than it is totally cold. Can't wait for all of the test results to come back!
    69
    82,162
    Re: Coolant level
    Yes, coolant, like anything else, expands when heated, thus the level rises a 1/2" or so. Goping down when hot is not a good sign. I assume it does not come back up?
    Apr 2004
    Albany, New York
    78
    214
    Re: Coolant level
    Ranger...by Right up there and full, I mean it is up to the metal crossbar inside the tank.
    69
    82,162
    Re: Coolant level
    Not familiar with that, but I suspect that is the half point and if so, that is right where it should be.
    Apr 2004
    Albany, New York
    78
    214
    Re: Coolant level
    Ranger. You asked if the level comes back up. As long as the engine is warm the level is down. When the engine gets COLD again the level goes back to normal range. I've checked it several mornings before starting the engine and it is always up where it should be.
    69
    82,162
    Re: Coolant level
    Holy shit Batman, that is the exact opposite of what SHOULD happen. I can't even begine to guess at how to explain that one.
    Apr 2004
    Albany, New York
    78
    214
    Re: Coolant level
    Yup!! That's what I thought. I'll let you know how the tests come out. The only time it overheats is when I'm on the way to Saratoga to gamble. Maybe it doesn't want me to lose money. LOL
    Feb 2006
    56,578
    Re: Coolant level
    Only way the level would go down, hot, is if there's a pint-sized bubble in a hose wall - as in: balloon. BUT, as soon as you cracked the tank cap to relieve the system pressure (dangerous operation!!!) the pressure would allow the "balloon" to collapse. Hmmmmmm..........
    Has anyone replaced the heater core and/or any coolant hoses in the past ?? Where I'm gong is that there may be a considerable air bubble in the system somewhere, and as the coolant heats that bubble compresses, thereby lowering the coolant level and simultaneously preventing water flow past the bubble. Stranger things have happened...............
    Apr 2004
    Albany, New York
    78
    214
    Re: Coolant level
    I had a new radiator installed almost three years ago. Only other thing I've done with the cooling system is a coolant change. Let's see what the tests show then if it's a really bad situation I'll just buy a Kia Spectra or something.
    Feb 2006
    56,578
    Re: Coolant level
    Albany............IF it needs a top overhaul, get it up to Jake.
  16. #14
    SPreston2001's Avatar
    SPreston2001 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Polo Green Metallic Cadillac STS 60K
    Dec 2008
    Columbus, OH
    34
    787
    Re: Coolant level
    No Kia talk in this forum
  17. #15
    Apr 2004
    Albany, New York
    78
    214
    Re: Coolant level
    Well the HG test proved negative so that's a good thing. Leak test found a small leak in the radiator which got worse as the coolant heated up. Leak is where the plastic meets the metal on the radiator. My man wants $600 as I guess it needs a new radiator. I told him I wanted everything checked before I spend another $600 on the Beast. My other option is to let it leak and carry a gallon of Dexcool in the trunk. Of course that means no long trips. I trust my mechanic but I still have a lot of concerns about this car even though I do love it. I've got to decide whether or not I want to keep it or get something more practical. Maybe not a KIA Spectra, probably a Ford Focus.
  18. Remove Advertisements
