can I recharge the A/C myself? 97 seville sts - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Cadillac Seville / Cadillac Eldorado Forum Discussion, can I recharge the A/C myself? 97 seville sts in Past Cadillac Vehicle Discussion; I did not. Hey, I'm no mechanic! Okay so the compressor has it's own oil, I will ask the dealer ...
  1. #16
    Mizugori is offline Cadillac Owners Member
    Automobile(s): 1997 Seville STS
    May 2009
    NY
    30
    54
    Re: can I recharge the A/C myself? 97 seville sts
    I did not. Hey, I'm no mechanic! Okay so the compressor has it's own oil, I will ask the dealer if they checked that to see if it had lost oil. Also, please note that when I bought the car at the end of May, it was completely out of refridgerant. The used car dealer took it to a mechanic and I think they just barely sprayed a little r134a in there, just to get it running so I'd buy the car. I am positive he did not fill it, not by a long shot. So it may not be a massive leak, it might be just that only a tiny bit had to leak to make it stop working.
    At the dealer, they diagnosed the a/c as described in my earlier post, and they put two cans of refridgerant in. I would certainly hope that they'd know to add oil also if it was needed, but I'll call and check with them. thanks!
  2. #17
    69
    82,262
    Depending on how low it is, it might only need a little R134a. The system only holds 2.2 lbs. If they put in two cans it was pretty low.
  3. #18
    May 2009
    NY
    30
    54
    I had said this in another thread, but the place I bought it from was pretty shady. I was tired of looking at dozens of these cars and I liked this one so I took a chance. But, back to my point, I overheard the salesman telling the mechanic to "only put 10 dollars-" and I assumed he was being a cheap prick and only barely topping off the refridgerant.
