Last week I was driving to work and I smelled brakes. Pulled in and noticed the LF brakes smoking! I know sometimes the hoses will pinch and not allow the brakes to release, so I changed the hose. Car drove fine for a few days, then it started doing it again. I saw the boot around the piston was torn, so I though maybe the caliper was hanging up. I proceeded to install both new front brake calipers and hoses (the rear brakes are just peachy). There was extensive damage done to the LF pads and rotors (which I just replaced about 3 months ago) so I resurfaced the rotors on a brake lathe and bought new pads, again. While I was in there I replaced the CV axle due to a torn boot and replaced the LF wheel bearing because I could hear a hum from it on the highway. The ABS light was on so I thought maybe the sensor in it was bad. Just finished up the job this morning and took the car out for a quick spin. It still seems like the brakes are sticking slightly because my MPG INST is showing about a 35%-50% reduction in mileage! I shift the car into neutral and it coasts, but the speed drops steadily. While in gear, the engine seems like it's working harder to keep momentum. I only drove about 2 miles and parked the car. I'm not gonna risk compromising all the work I just did.
The ABS light has been on since about the first of the year. I assumed it was the humming wheel bearing. I took it to the local dealer (O'Malley Cadillac) and paid $100 for them to tell me the ABS module was bad and a new one was $1000 + labor. The brakes were working fine so I opted out. They told me that the ABS module "lost communication" with the car and they couldn't even read the ABS codes. I recently purchased an ABS module from another forum member who is parting out a 2000 STS (I have a 2000 SLS so I'm assuming it should be the same module) I haven't put it in yet just due to the fact it looks like it's gonna be a chore (I do intend on replacing it though). Could the module be acting up and not allowing the brakes to release? Could there be a problem with the master cyclinder? Am I looking at it from the wrong angle?
Just curious if any of you other Caddy enthusiasts out there have come across or had a similar problem that you or had repaired. Any help, advice, or insight would be greatly appreciated.
