Cadillac Forums: 1986 Seville ... No Reverse
Old 06-14-09, 02:38 PM
Cadillac(s): 1986 El Dorado, 1986 Seville
View AlterMechaniker's Photo Album
Casino Cash: $435
My Seville no longer pulls in Reverse gear ... It will move forward in Drive, but No Reverse ... Any suggestions ?
  #2 (permalink)
Old 06-15-09, 02:45 AM
Casino Cash: $435
Re: 1986 Seville ... No Reverse
How about it folks ... I'm dying over here ...
I put the Trans in Drive, it pulls forward ... I put it in Reverse, it doesn't
even try to move at all ...
Note: The Trans was serviced (new fluid) recently.
HELP !!! ... I need to get this Baby back in action.
  #3 (permalink)
Old 06-15-09, 03:50 PM
iametarq's Avatar
Cadillac(s): 1998 SLS - 160,000 mi
View iametarq's Photo Album
Casino Cash: $10761
In the Chrysler forums we found that if there was not enough transmission fluid, we've had members lose their reverse...just an idea, i'm no expert on the subject.
  #4 (permalink)
Old 06-15-09, 04:10 PM
00 Deville's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2000 Deville / 2002 Deville
View 00 Deville's Photo Album
Casino Cash: $3900
It wasn't serviced with one of those flushing machines was it?
  #5 (permalink)
Old 06-16-09, 12:27 PM
Casino Cash: $435
The fluid level is correct and I still have NO Reverse ...
  #6 (permalink)
Old 06-16-09, 12:28 PM
Casino Cash: $435
No, it was serviced manually.
  #7 (permalink)
Old 06-16-09, 11:34 PM
Casino Cash: $435
Man, I wish it was an A/C problem instead .... I would have 10 pages of responses by now.
  #8 (permalink)
Old 06-16-09, 11:42 PM
Talamant3z's Avatar
Cadillac(s): 1997 Eldorado
View Talamant3z's Photo Album
Casino Cash: $5975
dont think so none of my ac threads got 10 pages haha i had to find out the old way trial and error i wish i could help but i know nothing of transmissions try asking on yahoo answers i get help from there sometimes
  #9 (permalink)
Old 06-17-09, 12:38 AM
Cadillac(s): 1990 Seville
View Sevillian273's Photo Album
Casino Cash: $9303
There is a fella named Edahall around here somewhere who I believe has experience servicing the THM-440. You could PM him for some insight but even if he knows what it is, it's still most likely going to be crazy expensive. Not alot can be done to the trans without pulling it from the vehicle and that alone is probably somewhere between $800 and $1200. Whether you have it replaced with a junkyard unit, a new unit, or have it rebuilt, you're still looking at big bucks. Is the car really worth it? Call around and see if you can get some free estimates....
  #10 (permalink)
Old 06-19-09, 12:41 PM
Casino Cash: $435
Okay ... I have dropped the trans pan again, checked for anything loose or broken, added new fluid (again) to the proper level and trans still does not function in Reverse.
Please Note: Prior to servicing the trans, it worked okay ... I changed the fluid as preventive maintenance.
If anyone has access to ALLDATA, please check their Diagnostic Section for this Transmission, then let me know what it says.
Thanks very much for your time.
  #11 (permalink)
Old 06-25-09, 01:49 AM
Casino Cash: $435
One last plea for HELP !!!
  #12 (permalink)
Old 07-10-09, 01:16 AM
Casino Cash: $435
Still hoping someone can help with this problem.
Car pulls just fine in Forward gears, but will not pull at all in Reverse.
  #13 (permalink)
Old 07-10-09, 03:38 AM
Casino Cash: $9303
OK, heres some info from the troubleshooting section of my factory service manual. Same trans, THM440 T4:
NO REVERSE
INSPECT COMPONENT FOR CAUSE
Fluid Pressure High or Low
Reverse Servo -Misassembled,
-Piston or seal damaged
-Wrong apply pin
Oil pump assembly
Input clutch Accum. Piston -Seal Damaged
Drive Link Assembly
Reverse Band -Burned, damaged, mislocated
Input clutch
Reverse reaction drum -Splines damaged
Input sprag
Input and reaction carriers
-END-
You need to take it to a professional. None of those items can be inspected with the transmission in the vehicle. Refer to post #9. Sorry bout your luck dude.
  #14 (permalink)
Old 07-11-09, 12:58 AM
Casino Cash: $435
Thanks for your help ... next stop, Tranny Shop.
  #15 (permalink)
Old 07-11-09, 02:31 AM
Casino Cash: $9303
I was just thinking..... maybe check the linkage between the shifter and the trans. I read somewhere that there was a recall about a c-clip coming off which would disconnect it from the trans....
EDIT: Heres the recal I was talking about http://www.automotive.com/1990/49/ca...lls/61062.html it doesnt look like it affects your year. But its still something to check out. Maybe the cable is just loose enough to not engage reverse. Its a shot in the dark...
If you take it to a shop, let us know what they find.
1986, reverse, seville
