service engine soon, Clicking sound?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Cadillac Seville / Cadillac Eldorado Forum Discussion, service engine soon, Clicking sound? in Past Cadillac Vehicle Discussion; got this 92 eldorado 136,00 miles 4.9 engine. started it up one morning and got this clicking noise that seems ...
    CharliB1989 is offline Cadillac Owners Member
    Automobile(s): 92 ELDORADO
    Sep 2008
    Maryland
    79
    Questionservice engine soon, Clicking sound?
    got this 92 eldorado 136,00 miles 4.9 engine. started it up one morning and got this clicking noise that seems to be coming from somewhere behind the oil filter(driver side by blower motor and transmission stick), service engine light is also on. puled the codes:
    (E026) ......................................... Shorted Throttle Signal Switch
    (E030) .................................................. . ISC RPM out of range
    (E040) .................................... Power steering Pressure switch open
    (E075) ................................................ Intermittent VSS Signal
    most of these is history.
    any help is appreciated.
    Sep 2008
    Maryland
    79
    Re: service engine soon, Clicking sound?
    i left out a code. Im thinking this is my problem.
    (E048) ......................... Exhaust Gas Recirculation (EGR) system Problem
    68
    81,913
    E048 is what turned on the SES light. Not sure about the clicking sound.
    Sep 2008
    Maryland
    79
    you think it could be stuck? .or should i just replace it with a new one.
    68
    81,913
    First thing to do is open the throttle plate and look down the TB. You will see two EGR tubes staring back at you. Be sure that they are open and not carboned closed. If so, rod them out.
    Sep 2008
    Maryland
    79
    i thought the egr was a mushroom looking part.
    68
    81,913
    Yes, that is the EGR "valve". It is controlled by an electrical solenoid and feeds the exhaust gases into the engine via the EGR tubes in the TB.
    Sep 2008
    Maryland
    79
    thanks for your help Ranger.
    i got the Service light to go out. turned out to be the tube on the throttle body going to the egr had come off.
    and for the clicking the mechanic told me to add some thicker oil. hopefully this works.
    you know any thing about heat and blower motors?
    68
    81,913
    I replaced one on my '97. What's the problem?
    Sep 2008
    Maryland
    79
    well my defrost wouldn't come on so i used my tester and found out the blower was no good. so i replaced the blower but still no defrost or heat. so now i have no idea what to look at next
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Quote Originally Posted by CharliB1989 View Post
    Not going to work. The ticking is because of your E026. What's making the ticking sound is the Idle Speed Control Motor. It's currently blind because of your shorted Throttle Position sensor so when you shut the car off it will try to find where the throttle should be for the next startup. Since it can't see where it is, it tries then fails a few times and makes that clicking noise.
    Edit: Wait, is the ticking happening while the engine is running? or right after you turn it off?
    68
    81,913
    So the blower works? Where is the air coming from?
    Sep 2008
    Maryland
    79
    Quote Originally Posted by Krashed989 View Post
    while the car is running theres a clicking sound.
  16. #14
    Sep 2008
    Maryland
    79
    i got a new blower but still no air coming from vents(no air blowing at all)
  17. #15
    68
    81,913
    Have you checked the HVAC housing on the firewall that houses the blower motor. If that has cracked all your air could be escaping under the hood.
  18. Remove Advertisements
