Vibration
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, Vibration in Past Cadillac Vehicle Discussion; Ok, I own a 2001 SLS that has a vibration feeling in the steering wheel. I don't think this is ...
    stealthregal is offline Cadillac Owners Member
    Automobile(s): 2001 Seville SLS
    Apr 2006
    Northern Michigan
    30
    Vibration
    Ok, I own a 2001 SLS that has a vibration feeling in the steering wheel. I don't think this is the normal front end vibration problem with my car.
    A little history first. I had a front wheel bearing go on me that I decided to replace. The whole process when south in a hurry and I wound up using a torch to get the bearing off since no amount of break free, heat, wax, bfh, or tension with a puller was going to remove it (sheared part of the plate off that the studs press into). After it was off I discovered that I had peened the end of the axle shaft some when trying to remove the bearing. I tired to grind the first two threads down and clean the rest up but decided to order a new axle to save time. My car is now back together and I have a vibration in the front that I did not have in the past. My tires were getting worn up front so I bought a set of Goodyear Eagle Response Edges that I had road force balanced. I also replace the front rotors and had a four wheel alignment done. I still have a slight vibration. It builds with speed and I notice it when turning the car (kind of feels like a slight binding). I spoke to a mechanic and he doesn't think the axle is the problem. Like I said the car rode great before the wheel bearing replacement.
    For the bearing assemblies I bought Timken parts and torqued everything to spec. The axle is a carquest part.
    Does anyone have any suggestions? I could buy a different axle and swap it out but want to limit any other possibilities first. I know that this sounds a little picky but this car rode smooth and I spent a fair amount of money for it. Thanks for any suggestions or help in advance.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,577
    Re: Vibration
    Probably not the axle assembly.
    Get the front end back up on jackstands and remove the wheels and rotors. Make very sure that the rotor-to-hub and wheel-to-rotor mating surfaces are absolutely clean. A small rust chip or sticky ID label in a new rotor will cause enough runout to give you a high speed shimmy.
    Torque the wheel studs to 100 ft/lb in a star pattern.
