Hub/Bearing and Axle: Diagnosis and Decision
Results 1 to 13 of 13
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hub/Bearing and Axle: Diagnosis and Decision in Past Cadillac Vehicle Discussion; I asked about this is another thread, wanted to move it here and stay on topic. 98 Seville. Had it ...
    kjd03842 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DeVille DTS
    Feb 2005
    NH
    228
    98 Seville. Had it up on jacks this afternoon. The noise is most prominent from the left inner joint assembly. Pretty bad, actually. Grinding / growling when the car is in gear.
    So while I may still have some bearing noise, I definitely have an axle problem. At 180K, considering I want to keep it on the road a while longer, should I just go ahead and replace axles and hub/bearings on both sides while I'm at it? Maybe even struts while I'm in there?
    Your opinion counts, thanks.
    finerwoodworking is offline Cadillac Owners Fanatic
    Automobile(s): 2003Cadillac Seville STS 75,000k
    Oct 2008
    Northern IL
    56
    178
    Re: Hub/Bearing and Axle: Diagnosis and Decision
    Had on bearing go out at 45k on the right front. The other is now going out on the left side at 48K and need to replace it now. When it was making the noise it was a weird sound and I thought it was the axle, or even a bad tire. I can't believe that the OEM bearings can be so crappy to go out in only 45k. No wonder GM is going down the toilet.
    iametarq's Avatar
    iametarq is offline Cadillac Owners Connoisseur
    Automobile(s): 98 Deville, '15 Ford Fusion Hybrid Titanium, '12 Ford Escape
    Dec 2004
    Petoskey, MI
    36
    3,294
    I just replaced my right front ORIGINAL bearing/hub assembly. It had 150,000 miles on it. My left seems fine except for a Speed Sensor fault once in a while when wet and going over big bumps. I haven't had time to see if its corroded wiring or what.
    If it were me, I'd replace the hubs, at least the one that is making the noise for sure. But I'm also wanting to get 200,000 miles on it before I retire it!
    69
    82,386
    Quote Originally Posted by finerwoodworking View Post
    45K is a fluke. Sold my '97 with 107K on it and never replaced one. '96 Bonneville has 160 and never been replaced.
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    Ever since purchasing my DHS (hybrid DTS interior ;-) ) I noticed while braking at high speed a vibration much like a warped rotor. This past weekend I went to get a lifetime alignment at Firestone and they came back telling me the left hub has play in it. I got this car at 76K miles. Now has 81K. I do sometimes feel it has the tendency to "channel" itself on cracks on the road, but that could be my imagination.
    Needless to say, the hub will be repaired. the oddity is the part that the Firestone wrote down does not say "wheelspeed sensor" included. So I wonder if it's a separate entity? Obviously I'm going with the AC Delco one with the built-in wheelspeed sensor.
    Question: how difficult is it to replace these things? I've replaced radiators, and done brake jobs, installed a blower motor (twice, complete with engine tilt), replaced oil cooler lines too.
    What tools do I need?
    Thanks.
    med's Avatar
    med
    med is offline Cadillac Owners Member
    Automobile(s): 1994 STS "CADDYSNACK"
    Mar 2007
    84
    I did my 94 STS several months ago. I had to use a torque wrench and a slide hammer. Unfortunately, normal hub pullers didn't work, so I used a NAPA 775-3911 slide hammer puller set. If your year is anything like mine then I believe you can do the job!
    69
    82,386
    Not a bad job. I did one on my '92 and it took me less than an hour. You will need a big 34mm socket for the axle nut.
    Feb 2005
    NH
    228
    Mine has that brake wobble too, I always figured tie rods just cause I hear so much about them here. Happens at city speeds too now. Brakes/rotors/calipers < 1yrs old, AC/delco.
    Bearings make sense. I'm really leaning toward doing both sides, bearings and axles. 180k -- I've gotten my money's worth.
    No mechanic has ever said my struts are bad, but I definitely wonder about those at this high mileage. What do I look for?
    ibdjakeson2's Avatar
    ibdjakeson2 is offline Cadillac Owners Member
    Automobile(s): 2006 STS-V, 2004 Escalade AWD Std
    Aug 2006
    Navarre FL
    93
    Great info on the vibration upon breaking. Always wondered what that was, now I will research more closely.
    Since you guys are on this topic, I've got a quick question. Every so often when I enter an uneven driveway or make a full left or right hand turn, I'll hear and arbitrary "pop" like an older balljoint used to make when they were going bad. I've noticed this on both my STS and my mother's SLS (both 00 models). I was wondering if this was common? Your thoughts?
    Thanks!
    Slay
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Leave the struts alone unless they have failed - they are expensive!
    69
    82,386
    Quote Originally Posted by ibdjakeson2 View Post
    Thanks!
    Slay
    Sounds like maybe a CV joint.
    Oct 2008
    Northern IL
    56
    178
    Slay
    How about a strut bearing, it could be bad?
    jbrown93etc is offline Cadillac Owners Member
    Automobile(s): 1993 Eldorado Touring Coupe
    Mar 2005
    Charlotte, NC
    45
    A torque wrench is not necessary to do the job (but would have been nice), I just used a long breaker bar. I'd say there are less steps than replacing the radiator but requires a little more muscle. Not bad at all.
  16. Remove Advertisements
