Originally Posted by 02Lackey I want to install satellite radio in my 2002 STS but I want to use the Onstar antenna as the antenna for the radio. Can this be done? I want to use that antenna because I want my car to look clean and not have that huge black circle on my roof with a wire running into my weather stripping. |
I cannot remember if 2002 Onstar could be upgraded to digital so I have to ask if your Onstar system is "active".
If your Onstar is active, you
do not want to use the Onstar antenna. Period.
If your Onstar is not active, I would ask why the antenna is still mounted on the rear glass. You would not be impressed with Sirius performance using a vertically oriented antenna. It would work and you would be fabricating a coaxial cable patch cord, but vertical antennas are famous for receiving equally poor in all directions.
Maybe a package tray mount Sirius antenna would be a better performance option with no ugly black circle on the roof. Even that choice is a compromise.
There is a very good reason for roof mounting antennas that are looking for signals from high above the equator.
