Cadillac Forums: Instrument Cluster Illumination
Old 12-31-08, 02:39 PM
Cadillac(s): 99 STS
View SwampeastMike's Photo Album
Casino Cash: $4615
I just fully disassembled a defective cluster from an '02 Seville. I wanted to scavenge parts and find out what those five small bulbs (accessed by removing the rear metal cover) are for.
Those five bulbs light the five blue-colored indicators--lights on, high beam, cruise control, and km/hr/MPH on either side of the speedometer itself. All of the rest of the indicators are lit by LEDs on the circuit board.
All of the background lighting is from a long (about 12") tiny diameter dimmable fluorescent tube.
Reasonably salvageable parts are the fluorescent bulb assy, the upper display unit, the lighted dial pointers and the dial motors.
  #2 (permalink)
Old 12-31-08, 03:29 PM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2200
Re: Instrument Cluster Illumination
Did you find a way to manually control the cluster brightness? I have a few choice words for the idiot that decided the driver could not manually set the cluster to full (daytime/lights off) brightness. Everything I've read in FSM has it sending the damn secret serial data messages back and forth between the IPC and the DIM to control the panel brightness.
  #3 (permalink)
Old 12-31-08, 06:11 PM
Cadillac(s): 99 STS
Casino Cash: $4615
I wish
Everything is on a single dual-sided circuit board with loads of hair-thin traces and mainly surface mount components--nearly as complex as a modern computer motherboard. Obviously assembled mainly by robot and soldered with some sort of solder bath in an oven as even the Phillips head screws securing heat sinks and connectors were mainly filled with solder.
As you said the dimming (both incandescent and fluorescent) is controlled via serial communication and once the light sensor in the dash detects "night" it commands all of the fluorescent displays and the tube in the cluster into dimming mode. I've worked some with dimmable fluorescents and found that there is usually quite a jump between "full on" and "maximum dim". I installed one dimmable fluorescent system that was nearly seamless, but in a land where any of the dimmable ballasts are expensive, it was hideously expensive.
I wish that a second ambient light sensor would have been installed (the casting is there in the defrost grille piece) to separate dimming from headlight operation. Will keep studying schematics for a way to add, but doubt that it's possible and almost certainly impractical.
  #4 (permalink)
Old 12-31-08, 07:12 PM
Casino Cash: $2200
Amen.
On my wife's 2000 Chrysler (which sold for less than half an STS) there's a setting on the dimmer switch that locks the flourescent displays on high. For twice the price to get an additional 90 HP I wouldn't think that option is rocket surgery. That said, every time I drive her car I can empathize with what the first Model T drivers must have endured.
cluster, illumination, instrument
