| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Difference Between ETC and ESC?
12-18-08, 10:10 PM
|  | Dreaded Office Pirate Cadillac(s): '98 ETC Black 86k miles | | Join Date: Oct 2008 Location: Lisle, Illinois Age: 24 | | Difference Between ETC and ESC? I was wondering last night what the difference is between the ETC and ESC models of the Eldorado. Aside from the output of the Northstar, which is apparently lower in HP but close to equal in torque, what (if any) are the other differences between the two models?
I have a 1998 ETC, which I bought for just under $5700 with just over 81K miles, and the other car I looked at was a 1997 ESC for $5300 with 99K. Both were in superb condition. I liked the color of the ETC (black) better than the ETC, which was a dark green shade, which helped contribute to my decision (as did the HP  ), but I do sort of wonder what I might have missed out on.
__________________ - C0RSA1R "Yea though I Ride through the Valley, I shall Fear no Evil, for I do Believe it's Time for a WOT." "You just said what he said, but he used the language of science while you used the language of bonghits-in-a-dorm-at-a-good-college." - jackbird "Justified anger is healthy, while unjustified anger is not. This is why Rush Limbaugh, angrier than ever under Obama, looks slim and fit in recent photos, while Michael Moore grew four extra chins during the Bush years." - Me |
12-18-08, 10:19 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2000 Cadillac STS 60K | | Join Date: Dec 2008 Location: Columbus, OH Age: 26 | | | Re: Difference Between ETC and ESC? Judging off the STS and SLS differences, I think besides the 25 extra horses in the ETC and torque differences, the ETC comes standard with wood grain interior, bose stereo, foglights, and has a more stiffer performance based suspension vs the ESC which has to add the additional trim packages and has a softer suspension. There may some other differences but those are the main ones. Try searching the forum im sure its been discussed hundreds of times. |
12-20-08, 01:21 PM
|  | Cadillac Owners Member Cadillac(s): 1997 Eldorado | | Join Date: Nov 2008 Location: Ohio Age: 19 | | | Re: Difference Between ETC and ESC? if your eldorado does not say ETC does that mean its the ESC because i dont have the bose or woodgrain finish, but it hauls you know what just like the etc |
12-20-08, 01:26 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2000 Cadillac STS 60K | | Join Date: Dec 2008 Location: Columbus, OH Age: 26 | | | Re: Difference Between ETC and ESC? Yeap its a ESC. The ETC comes standard with Bose, and wood grain finish. You wont be able to tell the difference in the 25HP, plus the ESC is quicker of the line due to the cams and gear ratio. |
12-20-08, 01:54 PM
|  | Cadillac Owners Member Cadillac(s): 1997 Eldorado | | Join Date: Nov 2008 Location: Ohio Age: 19 | | | Re: Difference Between ETC and ESC? i see. i wish mine was the etc model, but oh well, its still a caddy  |
12-20-08, 03:05 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Difference Between ETC and ESC? The ESC/ELC (Eldorado Sport/Luxury Coupe) series generally was rated at 275 hp with a final drive of 3.11:1. It will be a tad slower off the line but torque builds quickly, and will cruise at 200-300 rpm lower than the ETC, therefore slightly better gas mileage. The cam setup can be thought of as more of a "low rpm, high torque RV engine setup".
The ETC (Eldorado Touring Coupe) series generally has the 300 hp engine with a 3.71:1 final drive, so it is a tad quicker off the line, and power and torque build somewhat later than the ESC. The cam setup can be thought of as a more "performance/rpm" setup.
I say "generally" as regards horsepower ratings because, over the Northstar run, the SAE flywheel ratings for each model moved up and down a few HP.
You also need to know the speed limiter setting in your car: The driver's door tire sticker gives the ratings: S = 112 mph, H = 130, and W/Z = 154. The engine may be XXX hp, but if it is limited to 112 mph, you won't go any faster regardless of what you do........ |
12-20-08, 03:22 PM
| | my name is Tiffany Cadillac(s): 05 CTS-V | | Join Date: Mar 2003 Location: San 'tone, TX | | | Re: Difference Between ETC and ESC? thanks for joining as a supporter.
other folks should follow your lead http://www.cadillacforums.com/subscribe.html | | Cadillac Discussion Tools | | |
Censor is ON | | | |
