Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
    gregpoor is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 91 SDV, 01 SLS
    Aug 2008
    Ozarks
    127
    Thanks to Submariner409, for the "Butt Plug"
    Today I bought my first (and last) "Butt Plug" yea, I know...Thanks to Submariner409 for the detailed instructions, and by the way, when I took off the silencer, it was not even connected to the air duct tube hole, damm oil change place! This is why we do it ourselves I guess, to get it right. So I would check that out if you have the oil changed some where and they try to check the air filter,(which will never be allowed to happen again on my SLS), they won't get it back on right and clamped at most places I bet. It leaves an open unfiltered air path to the engine... wouldn't it?
    Based on what I read here, I went with the WIX brand, Air filter (I'm a recovering K&N spender) and really dig the look and the access to Trans.dip stick w/o the silencer.
    2001 SLS
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    Many
    submariner409's Avatar
    submariner409 is offline If it won't run, chrome it..... Cadillac(s) I Drive: 2002 Cadillac F55 STS/56000mi., 2004 Ford F150 Super cab 4x4
    Feb 2006
    Maryland upper Eastern Shore
    70
    17,135
    Re: Thanks to Submariner409, for the "Butt Plug"
    Thanks for the "Attaboy" ! If the air intake resonator had been completely disconnected from the 45 degree intake hose you would have had a very poor idle and possibly a few "lean" codes set. ANY air leak after that MAF totally screws up the A/F signals to the PCM, and a leak 2" in diameter will shut down the engine.
    The only thing that resonator chamber does is damp the intake noise which so-called CAI installs magnify, giving the impression of more noise = more power. Don't mistake noise for power: there are several ways to slightly modify your present intake system in order to gain slight power throughout the engine rpm range.......all the tricks are in here and Northstar Performance. The cars already have a perfectly good CAI as built.....all it takes is a bit of work and piping change to "be the best you can be", Northstar-wise. All in here for the past few years.
    Take a hard look at your existing airbox. Just outboard of the case, in front of the surge tank, is a good-sized hole into the driver's fenderwell. Using a long 3/4" hole drill or (more elegant) a Dremel tool, cut out the outside of the airbox to form a 2" x 3" hole near the fender hole. Make a foam gasket to tie the airbox to the fender hole. The existing MAF, piping, and TB connection are fine. You have now just doubled the available air volume to the filter panel and tract. BUT, you're still OK because the engine (280 c.i.) will never pull more than the new intake area can pass.
    Or, you can get a bit more creative and pull the headlight unit, remove the airbox, and remove the OEM air tube into the bottom of the airbox, open the hole, make a flex pipe from the larger hole down to the lower grille area. This, and the above mod, creates a true CAI, unlike some aftermarket add-ons which really use a cutesy top hat filter to draw in hot engine compartment air.
    Take a look at www.scangauge.com . Set up to monitor intake air temps, along with coolant, timing, and throttle opening. It will make a believer out of you.
    Aug 2008
    Ozarks
    127
    Good to hear that, when I lifted the silencer it seemed as though is was just sitting there on top without the plastic tie holding it, it was not done right, but good to know that no harm was done, as I didn't notice any issues. But now it's much better! I will get more into the other Air/mod latter, it's on the list... I have a lot of issues with my '91 sdv at the moment...PS my brother was a submariner & I did a few years on a tin can and a destroyer tender, good times.
    If I could ask you another question? I was replacing all the lamps in the trunk lid the other day, left it open for 2 days while i was getting some sealer to finish it and didn't want to close the trunk lid, (I changed them without totaly removing the pannel because the wireing harness was nicley sealed and I didn't really want to redo it)...I thought that the batteery power shut off after 10 min. so I didn't worry about the battery...I went out to complete the job tonight, and it's dead. darn it,
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    Feb 2006
    70
    17,135
    I forget the name of the module that controls "battery saver", but my accessory lights, OnStar, radio, etc. go dead after 10 minutes of no "key - on".
    urbanski is offline my name is Tiffany Cadillac(s) I Drive: 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,848
    thread title of the month
    CadillacSTS2003's Avatar
    CadillacSTS2003 is offline Zeeee-yaaaa Cadillac(s) I Drive: 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
    Oct 2005
    Cheswick, PA
    23
    15,377
    RIM i believe
    or its the BCM that controls it
    either way
    where the heck did you guys get that type of plug
    mines a plastic pvc cap that looks like crap
    Aug 2008
    Ozarks
    127
    Any hardware store plumbing section, 2" rubber pipe cap, comes w/ clamp $3.
    Mine fit purrrfect. See Submariner409's post. Some owner's have used a spray paint can lid and cut it. This one I got is thick black rubber, looks like it was OEM.
    Renew82 is offline Cadillac Owners Fanatic Cadillac(s) I Drive: Cadillac Seville STS 2003 47000 miles
    Aug 2008
    gurnee, il
    44
    127
    I glued mine in place with some rubber cement and tossed the clamp. Looks and works great.
    Aug 2008
    Ozarks
    127
    The pipe cap that I got was only about an inch deep, so I didn't need to cut it as sub409 did, but I did use a small amont of gasket sealer and the clamp not too tight, just snugged.
    Feb 2006
    70
    17,135
    Hey, Urb.........One thing not to do, either underway or in the barracks, is drop the soap in the shower..............
    Aug 2008
    gurnee, il
    44
    127
    It's not considered if it happens underway....
    Aug 2008
    Ozarks
    127
    Hey, do we get extra casino cash if we win the coveted "thread of the month" title? and will it help pay for my ever growing caddy list of things to do? I don't want to have to resort to earning extra $ at the local YMCA!
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: 2003 White Diamond DHS
    Jan 2005
    Dallas, TX
    2,110
    On my DHS I have clear access to the Trans dipstick... I shall study this more... has anyone removed said silencer on a Deville, or modded the intake piping? I don't even know where to start ... it appears there are differences. What should I search under? It appears the folks on the Deville forum aren't really into these kinds of mods... I'll check out the N* perf and hopefully will find a description that involves a Deville.
  16. #14
    Mar 2003
    San 'tone, TX
    23,848
    Quote Originally Posted by gregpoor View Post
    no, but i gave you a 1 month supporter. be sure to renew it
  17. #15
    Aug 2008
    Ozarks
    127
    That is very kind, (you know I was just kidding), but thanks, I wanted to become a supporter, and I will renew this, here is my problem, When I first signed up, If I remember back, I couldn't use my Yahoo email, so I tried my work e mail (State of Missouri) and it went thru. I went to buy Sal a drink the other day, and saw that the e mail of my paypal account needs to match the e mail for this site, so, if you can advise. I will get it right, I would rather not use that work e mail if poss. The site has been very helpful and I am learning to apprreciate the Caddy's more and more.
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
