Cadillac Forums: Wipers and washer problem
Old 12-15-08, 05:51 PM
View etozion's Photo Album
Casino Cash: $310
Question Wipers and washer problem
96 Cadillac Eldorado Wipers will not turn off and the washer fluid pump runs all the time as well If you turn the key off it will stop. I can not use my wipers because of that. Thanx God I'm in California!
Any idea how to fix it?
  #2 (permalink)
Old 12-15-08, 05:58 PM
View Ranger's Photo Album
Casino Cash: $24191
Re: Wipers and washer problem
Just fixed the same problem on my daughters '02 SLS. Hers turned out to be a broken (stuck on) washer button on the end of the wiper stalk.
  #3 (permalink)
Old 12-15-08, 06:04 PM
Casino Cash: $310
Any procedure how to fix it?
  #4 (permalink)
Old 12-15-08, 06:06 PM
Casino Cash: $24191
Does yours have a dedicated wiper/washer stalk with the washer button on the end?
  #5 (permalink)
Old 12-15-08, 09:49 PM
N*Caddy's Avatar
Cadillac(s): 1997 Cadillac STS
View N*Caddy's Photo Album
Casino Cash: $11525
Disconnect the Rainsense Module connector and make sure the Wiper/Washer switch is OFF. With the Ignition in RUN measure voltage between pin 6 and 7. Should be 0V. If voltage detected the culprit is the wiper/washer switch.
Going further, assuming the switch is OK (i.e. 0V) then reconnect the Rainsense connector and disconnect connector C1 form the wiper motor cover (C1 is the one with more wires). Measure the voltage between pin F to pin C on C2 connector (or any ground point). If not 0V then your culprit is the Rainsense Module.
If still 0V then your last culprit is the wiper motor control assembly (the electronics under the plastic cover). You will notice voltage between Pin D and E on C1 connector (should be 0V with wiper/washer off).
Just go on this road before replacing the switch on the upper steering column (although most of the time that is your problem).
All of the above measurements should be done with wiper/washer switch set to OFF and ignition in RUN.
I remember your problem Ranger, turned out to be what you were suspecting…
Tags: ,
problem, washer, wipers
