Replace Signal Flasher
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, Replace Signal Flasher in Past Cadillac Vehicle Discussion; The turn signals on my 1997 Eldorado stopped working. The hazard warning works fine, and I can make the turn ...
    TexasBandit is offline Cadillac Owners Member
    Jun 2005
    Memphis, Tennessee
    79
    The turn signals on my 1997 Eldorado stopped working. The hazard warning works fine, and I can make the turn signals work manually. It looks like the signal flasher needs replacement. Can someone "walk" me through this process? I read a thread from the forum already, but it did not have any details. Thanks ...
    greg-sls's Avatar
    greg-sls is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 SLS
    Jun 2007
    Phoenix
    550
    Re: Replace Signal Flasher
    If the 97 Eldo is the the same as my 97 SLS, you remove both the foot kick plate (plastic panel above brake pedal) and then the cover plate just below the steering column. You'll need to be able to reach up and find the flasher which is clipped into a hole inside the structure to the left of the column (between the column and the headlight switch). Once you've found it, press up on it and it should unclip and you can then remove the old flasher from its harness. I had to get a new one from a dealer. Reverse the process to install the new one.
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Edit: Greg beat me to the post button ^^^ his advice is probably better...
    Finding it should be the only hard part. After that it should be just pull out the old one and put in a new one. Given that I know zip about Eldo wiring I would start by turning on the flashers and localizing on the clicking - it may be under the dash near the dirvers feet or elsewhere. Is the turn signal relay near the flasher relay? You'd think they'd be close but this is a Cadillac. If you can find the hazard relay I'd look around and see if there's a similar looking relay nearby. Hopefully one of the gurus has done this and can give you a better idea where to start.
    One question though: do all the bulbs work? If you can make them come on manually have someone verify that both front and back bulbs on each side are working.
    68
    81,889
    Is your 4 way flasher switch on the column or the dash? If it is on the column, then you have 2 flashers I believe. One on each side of the column. The round one is for the 4 ways and the rectangular one is for the turn signals. If your 4 way switch (button) is on the dash, then button is attached to the flasher.
    Jun 2005
    Memphis, Tennessee
    79
    Thanks for the reply Ranger. I'll take a look at the kick panel today. If worse comes to worse, I'll just let my shop replace it when I change oil. My flasher is on the column. With my terrible mechanical ability, I may just wait. I have a bad habit of trying to fix things and end up making them worse!
    pauliecadillac is offline Cadillac Owners Member
    Automobile(s): 2005 XLR, 1996 eldorado
    Feb 2013
    10
    It took me days to find the turn signal flasher. I got a sore back and a big headache, but I found it. It is square black and it is clipped on a metal bracket under the dash to the left of steering colum right above the hood release. Remove the black plastick panel above the break pedal and then the cover under the steering wheel and the metal plate under that. If you look right above the hood release under the dash you will see a metal bracket. It is clipped to that. If you feel around the bracket u will be able to pop it off and there it is. Have fun.....BTW the hazzard flasher is located on the other side of steering wheel colum. It is round and silver. That one you can see. My symtoms were that tail lights would not flash and the signal indicators on the dash never lit.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    This is what you are looking for, is a 10 minutes job to replace.
  10. Remove Advertisements
