| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: 1999 STS Power window issue
09-23-08, 04:58 PM
|  | Cadillac Owners Member Cadillac(s): 2005 STS V6 1SC, R.I.P.1999 Cadillac STS | | Join Date: Sep 2008 Location: Huntingdon Valley, PA Age: 26 | | | 1999 STS Power window issue I'm having 2 different problems with the power windows in my '99 STS.
The passenger side front window won't move. The motor runs but nothing happens. I have the door apart but can't seen anything wrong with the window. Its seems that the motor is not connected to the regulator, any recommendations before i pull the regulator and motor assembly out.
Also both rear windows work just fine from the driver's control but not from their individual control. I was thinking that maybe there is a problem with the driver side switches possibly keeping them all locked. |
09-23-08, 05:18 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1999 STS Power window issue There should be a rear window lock out button on the drivers master switch. You probably have them disabled. |
09-23-08, 05:36 PM
|  | Cadillac Owners Member Cadillac(s): 2005 STS V6 1SC, R.I.P.1999 Cadillac STS | | Join Date: Sep 2008 Location: Huntingdon Valley, PA Age: 26 | | | Re: 1999 STS Power window issue Quote:
Originally Posted by Ranger There should be a rear window lock out button on the drivers master switch. You probably have them disabled. | First thing i tried, the light on the lock out switch comes on when you hit it but in either position it doesn't work from the rear switches. |
09-23-08, 05:42 PM
|  | Cadillac Owners Member Cadillac(s): 2005 STS V6 1SC, R.I.P.1999 Cadillac STS | | Join Date: Sep 2008 Location: Huntingdon Valley, PA Age: 26 | | | Re: 1999 STS Power window issue Just found one thing out, the windows go up from the rear switches when unlocked but not down... |
09-23-08, 06:01 PM
| | Cadillac Owners Member Cadillac(s): 98 STS | | Join Date: Sep 2005 Location: satellite beach fl | | | Re: 1999 STS Power window issue it's probably the same as my 98 sts front passenger window the motor and regulator are one piece with the motor riveted to the regulator and it is one part number, the whole assembly looks like a crossbow,with one continious wire and 3 pulleys i did not see any way to fix mine and did a lot of shopping on line and the local bone yards, i ended up buying one from rock auto because they werte the least expensive (only $45.00more than a 10 year old one from the bone yard $235 plus shipping |
09-23-08, 06:05 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1999 STS Power window issue It has to be something common to both windows than. I think you're gonna need a wiring schematic unless take a shot at throwing some parts at it, but that could get expensive. |
09-23-08, 07:21 PM
|  | Cadillac Owners Member Cadillac(s): 2005 STS V6 1SC, R.I.P.1999 Cadillac STS | | Join Date: Sep 2008 Location: Huntingdon Valley, PA Age: 26 | | | Re: 1999 STS Power window issue Found the problem on the passenger side window, the cable in the regulator is broken. |
05-18-09, 04:10 PM
| | Cadillac Owners Member Cadillac(s): 2000 Deville | | Join Date: May 2009 Age: 34 | | | Re: 1999 STS Power window issue my cable broke in my 2000 D'Ville, does anyone have a fix for this prob?? |
05-18-09, 10:22 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1999 STS Power window issue It's in the Tech Tips section. |
05-19-09, 01:30 PM
| | Cadillac Owners Member Cadillac(s): 2000 Deville | | Join Date: May 2009 Age: 34 | | | Re: 1999 STS Power window issue I looked through all nine pages of the tech tips section and the only one I found was regarding the plastic piece breaking and putting something there to hold the cable in place, But my cable is broken |
05-19-09, 09:41 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 1999 STS Power window issue In that case I believe you are SOL and will have to replace the motor. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
