Cadillac Forums: 1991 Eldorado Brake Light & Turn Signal Problem
Old 08-31-08, 11:49 PM
Cadillac(s): Cadillac
View Sammysm's Photo Album
Casino Cash: $335
I have a 1991 Eldorado and the brake lights and turn signals are not working. The high mount brake light and tail lights work but no brake lights and the turn signals are so dim you cant see them through the lens covers. I can't find any blown fuses or relays. What am I missing? Please Help!!!
  #2 (permalink)
Old 09-01-08, 03:44 PM
View Ranger's Photo Album
Casino Cash: $24266
Re: 1991 Eldorado Brake Light & Turn Signal Problem
Have you checked the grounds?
  #3 (permalink)
Old 09-02-08, 08:22 PM
Casino Cash: $335
Not yet...I checked the fuses and the switch and they seem to be working fine. You would not happen to know where these lights would be grounded at would you? Thanks for your help in advance.
  #4 (permalink)
Old 09-02-08, 10:28 PM
Casino Cash: $24266
Without a FSM for that year I really don't know.
  #5 (permalink)
Old 09-02-08, 11:14 PM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2200
I would bet on the gorunds as well - I would expect them to be somewhere in the rear fender well or trunk area behind the carpet. The other common part to turn signals and non-CHMSL brake lights is the turn signal switch in the steering column. If it has become carboned up or has a bad connection in the column wiring that could also be the source of your problem. Start by checking the voltage in the socket using both the socket connections and a known good ground.
  #6 (permalink)
Old 09-03-08, 03:08 PM
Casino Cash: $335
Thanks guys I will try these steps. Hopefully this will solve my problem. I will keep you posted.
  #7 (permalink)
Old 05-08-09, 03:44 PM
Cadillac(s): 1991 Cadillac Seville
View bcpape's Photo Album
Casino Cash: $295
Sounds like a classic grounding issue to me. Check all of your ground connections, escpecially your main ground to body.
Tags: , ,
1991, brake, eldorado, light, problem, signal, turn
