Cadillac Forums: Rear Brake Proportion Valve Replacement
Old 08-30-08, 02:24 PM
Dan78's Avatar
Cadillac(s): 1996 Cadillac Eldorado
View Dan78's Photo Album
Casino Cash: $6125
My the drivers side rear brake proportion valve on my 96 Eldorado has started leaking. Just by looking at it the thing looks like it is almost impossible to get to. I'm considering not touching this repair and letting a shop deal with the headache of replacing this, but thought I'd see if anybody has any hints or tips before I either tackle this myself to have a shop do it. Thanks in advance for any help or information.
  #2 (permalink)
Old 08-31-08, 09:28 AM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2225
Re: Rear Brake Proportion Valve Replacement
Not sure which part you're referring to; I thought there was only one proportioning valve that would be near the master cylinder under the hood. In any event, unless you are pretty adept, brakes are often best left to the shop. I'll do pads and rotors but much past that goes to my brake guy.
  #3 (permalink)
Old 08-31-08, 04:12 PM
Dan78's Avatar
Casino Cash: $6125
The service manual calls it a left rear proportioner valve. As far as brakes are concerned I normally only tackle pads and rotors and based on the location of this thing I am really leaning towards taking it in. I tried to get in there to tighten up the lines to see if that would stop the leak and found it extremely difficult to even get a wrench on the fitting.
  #4 (permalink)
Old 09-01-08, 05:00 AM
Krashed989's Avatar
Cadillac(s): 94 Eldorado, and a totaled z rated STS
View Krashed989's Photo Album
Casino Cash: $10958
It's not that hard although when I did mine i had to change a length of the brake line with it because the flare nut was all rusted. Just buy the new one first and take it to Napa or some auto parts store. One side requires a different size flare nut on the brake line but you wont find it, instead look for a brake line adapter for that side.
  #5 (permalink)
Old 09-16-09, 11:18 PM
newetc's Avatar
Cadillac(s): Eldo
View newetc's Photo Album
Casino Cash: $875
Mine has been acting up and now to the point i have to top off the brake fluid way too often..plus i got brake fluid all over the driveway.
is there a how2 thread or any special tools needed.. i have seen these go for about 47 bucks or so..
I need some help as well.. thanks you.. bump this up to get some more good responses.. thank you
  #6 (permalink)
Old 09-24-09, 01:45 PM
newetc's Avatar
Cadillac(s): Eldo
Casino Cash: $875
Bringing this thing up.... been looking for more info and so far very limited.. the dealer wants 200 bucks to fix it.. not bad but a new part should run less then 50 bucks.. what else to replace when in there.. i know it is way tight to replace.. thanks for the help..
Tags: , ,
brake, proportion, rear, replacement, valve
