| Re: Normal Cooling Fans Operation ??? After a little time to digest...
The motors are not 2 speed, so if they work in one mode, they are good.
Since there is voltage avalible to one side of the contact all the time.
Does the PCM provide + to the coil or ground.
I bench tested my relays and they all work, so I'm thinking that maybe I have a corroded ground so the coils might not be pulling in.
Now that I know how they should work, I can get my IR temp gun and watch what happens as it warms up to confirm there really is a problem with the fans.
While you are watching, I'm replacing the T-stat. What's the best method to the coolant mix back in the system with the least amount of air?
Thanks! |
