Cadillac Forums: Power Loss Update
Old 08-05-08, 04:57 PM
Cadillac(s): Cadillac
View Mark Grochowski's Photo Album
Casino Cash: $390
Power Loss Update
Still having a power loss issue w/ my very clean 1990 Seville (120K). At Highway speeds going up a grade . At 75 mph The tranny drops out of OD then I slow down to 60 mph . I got the thing floored. It will eventually go in the passing gear real hard. Like I'm getting rear ended. No codes except E30 History. The Tranny Fluid is very clean. The throttle body is also clean.
No catalytic convertor (test Pipe) New Fuel filter. Any Ideas??
Thanks,Mark
  #2 (permalink)
Old 08-06-08, 04:31 PM
Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante
View carnut's Photo Album
Casino Cash: $7920
Re: Power Loss Update
Possible weak fuel pump pressure. You need to verify fuel pressure is at spec when this occurs. Install fuel pressure gauge with a long enough hose to be able to tape the gauge to the winshield.
  #3 (permalink)
Old 08-11-08, 02:04 AM
Cadillac(s): 1993 Eldorado Touring Coupe
View jbrown93etc's Photo Album
Casino Cash: $520
Mine just did this too starting a week ago, im almost positive its the fuel pump. I was on a long trip and it started doing it when my fuel was getting low, I'm suspecting you were below a 1/4 tank as well. I had a few gallons of gas left and got off a exit and it died on the exit ramp, would not restart. Added a gallon of gas and made it to the gas station going 10mph. When I filled it up it ran perfect again.
  #4 (permalink)
Old 08-11-08, 06:29 AM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $1025
Sounds a little like the classic fuel tank baffle collapse problem causing the pump to starve, although that was usually in turns as opposed to going up or down.
loss, power, update
