| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Program Homelink to Craftsman garage door opener
08-05-08, 03:21 PM
| | Cadillac Owners Fanatic Cadillac(s): 1995 STS | | | | | Program Homelink to Craftsman garage door opener I followed the instructions in my manual to program my homelink for my Craftsman garage door opener to no avail. When it flickers to show that it's programmed, it will not work.
Can anyone tell me what's the right way of programming this? Thanks. |
08-05-08, 06:14 PM
| | Cadillac Owners Fanatic Cadillac(s): 1995 STS | | | | | Re: Program Homelink to Craftsman garage door opener Are you guys going to tell me that not one single person here knows how to program the Homelink garage opener??? |
08-05-08, 06:21 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2000 STS, Past : 99 STS, 94 STS | | Join Date: Aug 2004 Age: 30 | | | Re: Program Homelink to Craftsman garage door opener I do my dad owns a garage door buisness. Assuming you have the homelink with the yellow light as that is the only one that will work with security plus openers. Hold down one of the buttons on your homelink until it begins to flash then push and hold the button on one of your remotes. Once it is programed go to the motor in your garage and push the learn button then run or get someone else to push the button you programed inside the car. Any questions pm me. Note if you have the homelink with the red light I don't think it will work but on a good note you can remove the unit from your car and get a replacement on ebay or from your local dealer just make sure it has the amber light. |
08-05-08, 06:34 PM
| | Cadillac Owners Fanatic Cadillac(s): 1995 STS | | | | | Re: Program Homelink to Craftsman garage door opener I have the red light kind. I had it working until I installed a new Craftsman garage door opener. I guess it has a rolling code. Is there a way to program with this kind of opener? |
08-05-08, 08:26 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2000 STS, Past : 99 STS, 94 STS | | Join Date: Aug 2004 Age: 30 | | | Re: Program Homelink to Craftsman garage door opener No security plus or rolling code is not compatible with the red light kind. However the homelink unit in your car is removeable. Take it out and sell it on ebay then find the one with the amber light and it will work. |
08-05-08, 09:55 PM
| | Cadillac Owners Fanatic Cadillac(s): 1995 STS | | | | | Re: Program Homelink to Craftsman garage door opener People will buy my homelink? How much should I sell it for? |
08-05-08, 11:04 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Aug 2008 Location: Allen, Texas | | | Re: Program Homelink to Craftsman garage door opener Try this.
1. Press and hold the two outside homelink buttons (1 & 3) in for 30 seconds (the little amber LED light should flicker then go out/off).
What this does is erase anything that was previously programed.
2. Hold your garage door remote close to your homelink buttons then press and hold your remote button and homelink button (the one that you wish to program) in at the same time for 30 seconds.
What this does is match up your remote and homelink.
3. Push the learn button on your garage door opener one time, the LED should come on and stay on.
What this does is puts your garage door opener into the programing mode.
4. Go back to the vehicle and press and hold the homelink button that you programed earlier until you see the garage door opener light come on and go off.
5. Remember that the homelink system does not function like a garage door opener remote, you usually have to hold the homelink button in a little longer.
6. Everyting should work just fine.
Kevin Kodama |
08-05-08, 11:11 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Aug 2008 Location: Allen, Texas | | | Re: Program Homelink to Craftsman garage door opener did you get the info? |
08-06-08, 12:08 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 SLS - 160,000 mi | | Join Date: Dec 2004 Location: Petoskey, MI Age: 28 | | | Re: Program Homelink to Craftsman garage door opener yes, did you get it to work? Rolling code DOES work. It is not quite like it is in the manual. I have my parents rolling code door programmed on my seville and my parent's deville. |
08-06-08, 06:29 AM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: Program Homelink to Craftsman garage door opener As Dwight posted, rolling code doors require the amber light Homelink module. Red light units will only do fixed code. When I bought mine on eBay I think I paid ~$45 for a rolling code unit. Search completed auctions and see what they have been selling for. |
08-06-08, 07:56 PM
| | Cadillac Owners Fanatic Cadillac(s): 1995 STS | | | | | Re: Program Homelink to Craftsman garage door opener Nope. It doesn't work. You sure it will work with the rolling codes and the red light Homelink? |
08-06-08, 08:57 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2000 STS, Past : 99 STS, 94 STS | | Join Date: Aug 2004 Age: 30 | | | Re: Program Homelink to Craftsman garage door opener It won't I use to go program them for customers when I worked for my dad. It must be the amber light on the unit otherwise it will not work. |
08-06-08, 11:44 PM
| | Cadillac Owners Fanatic Cadillac(s): 1995 STS | | | | | Re: Program Homelink to Craftsman garage door opener I guess it's time to hit the junkyard and snatch one off of a Caddy. How do I know it's the amber light with the power off? Is it color discernable? |
08-07-08, 02:51 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2000 STS, Past : 99 STS, 94 STS | | Join Date: Aug 2004 Age: 30 | | | Re: Program Homelink to Craftsman garage door opener Yes you should be able to tell if it is the right one. |
08-07-08, 02:53 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2000 STS, Past : 99 STS, 94 STS | | Join Date: Aug 2004 Age: 30 | | | Re: Program Homelink to Craftsman garage door opener Here is the link for programming homelink and you may be able to find other info on the site. http://www.homelink.com/training/train.taf | | Cadillac Discussion Tools | | |
Censor is ON | | | |
