| Re: Help with steering wheel and airbag Wait a minute… this is same as mine…97 STS and I did mine few months ago (well better put that one year ago).
I think I remember, that connector goes in one of the two holes used to extract the steering, is just a grounding of the steering wheel (correct me if I am wrong).
Don’t worry about blowing the air bag as long as you disconnected the battery (at least 15 minutes before unscrewing stuff). If you need to be extra safe wear an electrostatic bracing, and always remember keep at least 15 inches away from the airbag while working on it. When you will connect the battery you will be by the battery (i.e. away from the airbag) so even if something is wrong you are away.
You might have troubles getting the horn to work (I did), that spring is a PIA to arrange properly. If no worky, disconnect the battery, wait 15 minutes or so and then rearrange the horn (safety first).
Also make sure nobody opens the garage door exactly when you disconnect the airbag connector (I jumped out of the car when that happened to me in exactly the mentioned moment). |
