Results 1 to 8 of 8
Thread: Oil Cooler Leaking?
    66 elcam is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Eldorado Touring Coupe
    Jul 2008
    Windsor, Ontario, Canada
    31
    40
    Oil Cooler Leaking?
    hey everyone, new here. I drive a 93 Eldorado Touring Coupe. Had it for about a year now and absolutely love it. the car has developed what appears to be an oil leak from the oil cooler. did a search, couldn't really find if this is a common problem but it appears to be from the fitting. does an o-ring need to be replaced or something? or is it the line?
    attached are some pics
    thanks!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,794
    Re: Oil Cooler Leaking?
    You shouldn't double post.......
    That looks like a quick connect or flare setup. One of our resident GM Techs will have to answer this one........With that remote cooler I'd let a shop take responsibility........
    Welcome to the Looney Bin !!!
    Raze's Avatar
    Raze is offline Cadillac Owners Enthusiast
    Automobile(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
    May 2004
    Atlanta, GA
    34
    963
    That's a quick disconnect w/a plastic lock ring inside the fitting that origionally clamps over the flared end of the hose and locks into the metal fitting, there is a simialr plug going into the passenger side tank of the radiator (where the oil cooler is) on later year N* equipped cars. Luckily for you it's pointed down so when the plastic piece becomes brittle with age and cracks oil squirts down and hopefully far enough away from your tire so you don't go skating. On the later years it's directly in line with the serpentine belt so when it breaks you blow oil all over your belt and toss it at 65mph in the middle of rush hour traffic in Atlanta when it's 90 deg outside
    Unsrew the large metal adapter from the cooler, from the top squeeze in the plastic fitting so it'll pop the hose out, go to autozone or advance with the plastic fitting and find a new one. I had to actually buy a whole new metal adapter ($8) to get the right size plastic ring from an LT1 or some such nonsense but they do sell variety packs of rings ($4)...
  5. #4
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    id clean all that off with some brake cleaner 1st and make sure you pinpoint the leak before throwing parts at it
    thats a viable mess and could be coming from the lines itself or maybe the tank...
    at high pressure it has enough force with a small crack to spray everywhere like it has
    check 1st repair once
  6. #5
    Jul 2008
    31
    40
    Quote Originally Posted by submariner409 View Post
    sorry, when i posted it said i was spam and i didnt know if it worked so a tried it again.
    thanks for the welcome.
    ill clean it up and try and pin-point the exact leak and see what parts i need.
  7. #6
    Jul 2008
    31
    40
    ok so its not the o-ring. the leak is at the top of the fitting. the actual cooler tube is leaking.. any thoughts? so i just go with an after market cooler, or oem.
  8. #7
    69
    82,262
    Is that an oil cooler or a trans cooler? I'd take STS2003's advice and clean it up good first to pin point it.
  9. #8
    Necrosan is offline Cadillac Owners Enthusiast
    Automobile(s): 1994 Cadillac Eldorado Touring Coupe
    Jan 2008
    MKE
    821
    My 94 Eldorado just developed this issue.
    Gonna try Razes advice in a second and pray it works!
  • You may not post replies
