| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Quick question please
06-25-08, 04:40 PM
| | Cadillac Owners Fanatic Cadillac(s): 2002 Black Inside and Out Seville SLS | | Join Date: Mar 2007 Location: Borderline rural Michigan Age: 55 | | | Quick question please Just a real quick question, if you please. 2002 Seville SLS, axel nut size. 30 mm, 34 mm, or 36 mm? I'm replacing a front hub assembly. Besides a hub puller, what else might I need? It was difficult to locate the faulty hub, front or rear, on the side that is loaded when the "roar" happens. But I figure it must be the wheel that is much warmer.
I think I should be able to locate this nut size info in the FSM, but I haven't been able to. Am I just missing something obvious?
Thanks. |
06-25-08, 05:25 PM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: Quick question please FSM assumes you have a full set of GM spec tools so its sometimes a little sketchy on details like that. I wouldn't even be surprised if it turns out to be SAE. That said, I wish I knew the answer for you  |
06-25-08, 07:57 PM
| | Cadillac Owners Fanatic Cadillac(s): 2002 Black Inside and Out Seville SLS | | Join Date: Mar 2007 Location: Borderline rural Michigan Age: 55 | | | Re: Quick question please Even with a full set of tools, why wouldn't it specify which one of this full set of tools to use?
I feel confident it's metric since I've seen some talk about wheel hubs in these forums that say so, but not size. And I found the following webpage that is specific about GM FWD: http://www.mytoolstore.com/kd/kdbrak11.html
I have to do a front hub on my 95 Bonneville, too. On the pontiacbonnevilleclub.com site I found that it will require 34 mm. I guess I'll play with advanced search for a while and see if I can get lucky. Thanks for the response. |
06-25-08, 08:14 PM
| | Cadillac Owners Fanatic Cadillac(s): 2002 Black Inside and Out Seville SLS | | Join Date: Mar 2007 Location: Borderline rural Michigan Age: 55 | | | Re: Quick question please For the record, I found this, which satisfies me:
These instructions came from a 2002 Buick Lesabre Limited, however they will work for numerous GM front wheel drive vehicles including:
Buick Lesabre, Park Avenue, Centruy, Regal, Riviera, Rendezvous
Cadillac Concours, Seville, Deville, Eldorado
Chevrolet Impala, Monte Carlo, Venture
Oldsmobile Aurora, Intrigue, Silhouette
Pontiac Aztec, Bonneville, Grand Prix, Montanna, Transport
8. Remove axle nut using 1 5/16″ or 34mm socket. http://www.autopartsdirecttoyou.info/?p=12 |
06-25-08, 10:34 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Quick question please I just went out and checked this a few weeks ago for someone and I am almost positive it is 34mm. |
06-25-08, 10:40 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Quick question please just did mine the other day
2003 Seville STS
34mms
Tighten the wheel bearing and hub retaining bolts to 130 N·m (95 lb ft)\
i didnt need a special puller to remove it even with 60K on the clock just a nice sized brass hammer did it...
heres the whole GM speel on how to do it:
Wheel Bearing/Hub Replacement - Front
Tools Required
J 28733-B Front/Rear Spindle Remover
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the wheel and tire. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Object Number: 402796 Size: SH
Click here for detailed picture of above image.
3. Insert a drift punch (1) or screwdriver into the caliper and rotor to prevent the rotor from turning and remove the wheel drive shaft nut.
4. Remove the brake rotor. Refer to Brake Rotor Replacement - Front in Disc Brakes.
Object Number: 105002 Size: SH
5. Disconnect the front wheel speed sensor electrical connector and unclip from the dust shield.
6. Vehicle equipped with brake wear indicator sensor, disconnect and unclip from the dust shield.
Object Number: 397703 Size: SH
7. Remove the wheel bearing and hub retaining bolts and dust shield.
Object Number: 105004 Size: SH
Important
The wheel bearing and hub are replaced only as an assembly.
8. Using J 28733-B separate the wheel bearing and hub from the drive axle.
9. Remove the wheel bearing and hub and dust shield.
Installation Procedure
Important
Clean rust and foreign material from the knuckle mounting face, bore and chamber to allow for proper seating of the bearing and knuckle.
1. Install the wheel bearing and hub and dust shield to the drive axle.
* Apply a light coating of grease to the steering knuckle bore.
* Do not handle the wheel bearing and hub assembly by the ABS sensor wire.
2. Install a new drive axle nut and draw hub and bearing onto the axle.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
3. Install the wheel bearing and hub retaining bolts.
Tighten
Tighten the wheel bearing and hub retaining bolts to 130 N·m (95 lb ft).
4. Connect the front wheel speed sensor electrical connector and clip to the dust shield.
5. Vehicles equipped with brake wear indicators connect the sensor electrical wire connector and clip.
6. Install the brake rotor. Refer to Brake Rotor Replacement - Front in Disc Brakes.
Object Number: 402793 Size: SH
7. Insert a drift punch (1) or screwdriver into the caliper and rotor to prevent the rotor from turning.
Tighten
Tighten the wheel drive shaft nut to 160 N·m (118 lb ft).
8. Install the tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
9. Lower the vehicle. |
06-25-08, 10:48 PM
| | Cadillac Owners Fanatic Cadillac(s): 2002 Black Inside and Out Seville SLS | | Join Date: Mar 2007 Location: Borderline rural Michigan Age: 55 | | | Re: Quick question please Thanks for the info, guys. 34 mm it is.
BTW, my FSM says torque axel nut to 107 lb. ft., but mine is a 2002 SLS. |
06-25-08, 10:51 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Quick question please Lemme check GM ESI on that and post back |
06-25-08, 10:53 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Quick question please Document ID# 684174 2002 Cadillac Seville
Tools Required
Removal Procedure
Important
Important
Notice
Tighten Tighten the wheel bearing and hub retaining bolts to 130 N·m (95 lb ft).
Object Number: 105002 Size: SH |
06-25-08, 10:54 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Quick question please GM esi (electronic service information) which has since outdated the use of the older manual still states for 02 or 03 95 ft lbs
its your call on what to do but id trust the GM database which was last updated in 05 over the manual printed in 02.... |
06-25-08, 11:20 PM
| | Cadillac Owners Fanatic Cadillac(s): 2002 Black Inside and Out Seville SLS | | Join Date: Mar 2007 Location: Borderline rural Michigan Age: 55 | | | Re: Quick question please I called it the axel nut, but, as your instructions show, it's actually the wheel drive shaft nut that my book says is 107, where yours said 118. Sorry about the confusion. Mine says 95 for the wheel bearing bolts, too.
I'm hoping the corrects spec will be included with the nut. It looks like a dealership-only item. |
06-25-08, 11:25 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Quick question please the hub?
not a dealer item by a long shot... |
06-27-08, 12:22 PM
| | Cadillac Owners Fanatic Cadillac(s): 2002 Black Inside and Out Seville SLS | | Join Date: Mar 2007 Location: Borderline rural Michigan Age: 55 | | | Re: Quick question please No, the nut. I couldn't find one anywhere online. It's the same nut, same part number, for both cars. A $15 nut.  |
06-27-08, 06:15 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: Quick question please I have never changed the axle nut - I have always re-used it and never had a problem. I guess it can't hurt to put a new one on, but that's up to you |
06-27-08, 06:27 PM
|  | Cadillac Owners Fanatic Cadillac(s): NONE | | Join Date: Sep 2007 Location: Wilmington, NC Age: 29 | | | Re: Quick question please traditionally called a 'castle' nut because it has the notches for your cotter pin to fold into | | Cadillac Discussion Tools | | |
Censor is ON | | | |
