| Re: Front Calipers sticking Could be either as well as guide pins not lubricated. The caliper slides on the pins that hold it on to the spindle. With the wheel off, wedge a large screw driver between the inboard pad and rotor and force the pad into the caliper. Once retracted, you should be able to easily slide the caliper back and forth on the guide pins. If not, remove each pin one at a time and lube with silcone brake grease. If still binding, I would suspect the brake hoses going to the caliper. They can deteriorate internally, effectively blocking fluid flow back to the master once the pedal is released. |
