| No Distributor Signal- '92 STS Hello All,
I could really use a little input form you all. Recently, my '92 STS has intermitently quit running, or refused to fire up- ran the codes...a few to choose from, but the problem seems to be...
E012- No Distributor Signal (Current anytime it won't run, as well as in History)
also in History:
E030 ISC Rpm Out Of Range
E052 PCM Memory Reset
E053 Distributor Signal Interupted
I052 Keep Alive Memory Error
R033 Steering Diode Shorted In Arming Sensor
R034 Dual Pole Arming Sensor Ignition Feed Open
Thought I should mention that the car did sit for a while with a discharged battery- dropped in a new one, and off we went. All was well for several weeks, then it wouldn't fire up one day (for my Wife, of course!).
Seems that it only occurs when the engine is warm, and if left to sit for a while it always starts. Only time it has stalled while driving is at a stop, and I think that's due to the idle being to low. If I keep it running, it seems fine.
Oh yeah, I'm proud to announce that I've just turned over 200,000 miles!
Any ideas? Thanks in advance!
Doug |
