Originally Posted by Krashed989 Those are tires with different widths. That doesn't mean the outer diameter is different. |
Yes it does.
Tire sizes are designated as such: P235/60 R16
There may be other letters in there, but these are the important ones as far as size is concerned.
Breaking it up, the different codes are:
P - passenger car
235 - Tread width (235 mm)
60 - Series or Aspect Ratio - this is the height of the sidewall as a percentage of the tread width: 60% of 235 mm, or 141 mm
R16 - 16 inch rim
So since the tires were both 60 series, the 225 had a diameter of 26.6" and the 235 had a diameter of 27.1".
It was only a half inch difference, and I didn't realize they were mismatched until I rotated them front to rear. The car looked funny and thats when I checked the sidewalls. Like I said, I didn't have any codes come up, and there isn't any reason that there would be any mechanical wear, you could definitely step up to a 245/60 in the rear and create a little bit of a rake.
