  Follow CadillacOwners on Twitter
Cadillac Forums: Engine won't crank
Old 04-30-08, 08:35 AM
Cadillac(s): Cadillac
View micheleb156's Photo Album
Casino Cash: $285
Angry Engine won't crank
1989 STS Engine won't crank new starter, alternator, battery serpentine belt, plugs, wires, idler pulley...... Won't crank over turn the key and nothing anybody have any suggestions as to why? What might be causing this?
  #2 (permalink)
Old 04-30-08, 09:31 AM
Cadillac(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'97 seville
View Harry Yarnell's Photo Album
Casino Cash: $3875
Re: Engine won't crank
Can't remember if the '89 STS has Passkey or not, but that feature could be problematic. PRNDL switch is another possibility. Dead battery caused by an internal light being on...these are the first things I'd look at. There are many other possibilities. Do the lights work? Radio?
  #3 (permalink)
Old 04-30-08, 10:36 PM
Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante
View carnut's Photo Album
Casino Cash: $9070
Were all these items replaced to hopefully get the engine to crank over? does the battery pass a load test? Does the car have a factory alarm or any aftermarket alarm? do the headlights dim when the key is turned to the start position?
  #4 (permalink)
Old 05-01-08, 01:30 AM
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2810
If its dead nothing - no solenoid click or starter engagement its likely the VATS system. Two little wires in the steering column that have a tendancy to break over time and cause the anti-theft system to engage. Search on VATS or VATS bypass. If you can find and jump the starter enable relay you can determine if that is the problem. Also read up on 'neutral safety switch' although those failing is much less frequent.
  #5 (permalink)
Old 05-01-08, 04:01 AM
Krashed989's Avatar
Cadillac(s): 94 Eldorado, and a totaled z rated STS
View Krashed989's Photo Album
Casino Cash: $13058
Put the shifter in Neutral and try it. If it starts up fine with the car in neutral, it's a bad neutral safety switch.
Tags: , ,
crank, engine
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
