Cadillac Forums: 99 eldo, only complaint after first few weeks
Old 04-23-08, 12:12 PM
K_cin_az K_cin_az is offline
Cadillac(s): 1999 Eldorado ESC
View K_cin_az's Photo Album
Casino Cash: $1925
Well I am throughly enjoying my 99 eldo. The ride is so smooth I feel like I am floating down the highway.
The only thing I dislike about it so far is it seems that it gives off a good amount of heat from the engine into the car. I am wondering if it is something pacific to my car or if that is kind of standard.
  #2 (permalink)
Old 04-23-08, 12:20 PM
Raze's Avatar
Raze Raze is offline
Cadillac Owners Enthusiast
Cadillac(s): 1990, 1998 Eldorado
View Raze's Photo Album
Casino Cash: $1630
Re: 99 eldo, only complaint after first few weeks
turn your digital temp down to 60, if it's up at 75+ your car circulates/vents air from the engine bay around that temp even if the system isn't on, otherwise actually turn on your A/C and you should have no problems...
  #3 (permalink)
Old 04-23-08, 01:51 PM
Casino Cash: $1925
thanks for the tip! I thought since I had it off it wouldn't be running....
  #4 (permalink)
Old 04-23-08, 04:07 PM
submariner409's Avatar
submariner409 submariner409 is online now
If it won't run, chrome it !
Cadillac(s): 2002 Cadillac F55 STS/47800mi., 2004 Ford F150 Super cab 4x4
Casino Cash: $8924
The HVAC system will always try to maintain the last set driver/passenger temps even though the system is "OFF". The blower doesn't run: the blend doors stay where they were when you push the Driver temp/on/off button to turn everything off. There's a quiet little hidden statement to that fact in m '02 owner's manual. So, if you've been enjoying nice, dry 70 degree air with the a/c on, and shut the system down, as the outside temps go to 90 the system is still trying to supply that 70 degree air, but with no a/c drying (and therefore cooling) effect.
  #5 (permalink)
Old 05-09-08, 01:39 PM
Casino Cash: $1925
I still havent been able to figure out how to stop the vents from being open and having the hot air come in around my legs. Is there definetely a way to do this that I am missing? Ive tried turning my temp down and then setting to off but that didnt cut it out.
  #6 (permalink)
Old 05-09-08, 01:47 PM
CadillacSTS2003's Avatar
CadillacSTS2003 CadillacSTS2003 is offline
AKA CadillacETC1997
Cadillac(s): 03 STS, 97 ETC, 98 STS, 05 STS, 06 STS-V, 74 Eldo Vert
View CadillacSTS2003's Photo Album
Casino Cash: $5050
adjust the a/c level to read 60 degs
turn the a/c off
problem solved
if its still blowing hot your a/c system is farked
  #7 (permalink)
Old 05-09-08, 03:51 PM
Casino Cash: $1925
ill try that again, i may not have adjusted it to 60 before i turned off.....
  #8 (permalink)
Old 05-09-08, 04:23 PM
cadillacroadside cadillacroadside is offline
Cadillac(s): Cadillac
View cadillacroadside's Photo Album
Casino Cash: $1400
are you refering to heat in the car when hvac is off?? if so put the hvac sysetm in recirc mode and turn off the havc system this will not allow outside air while you are driving
  #9 (permalink)
Old 05-09-08, 09:10 PM
Ranger Ranger is online now
View Ranger's Photo Album
Casino Cash: $10961
Maybe you have an air mix door actuator failed in the open position allowing heat into the cabin no matter where you set the temperature.
  #10 (permalink)
Old 05-09-08, 09:13 PM
AKA CadillacETC1997
Casino Cash: $5050
yup
like i said
if that aint fixing it then there gotta be an issue with the system
see if you have any blend or mix door codes...
Tags: , , , ,
complaint, eldo, weeks
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
