| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Little Rough Idle at Cold Start
04-22-08, 05:31 PM
| | Cadillac Owners Member | | | | | Little Rough Idle at Cold Start Dear Cadillac Enthusiasts,
I have a 1998 Seville STS with around 93K miles. In the morning, when the engine is cold, it is sometimes a little rought at idle until it warms up. Is it time to tune?
-alan |
04-22-08, 06:33 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1996 Deville (sold), 2000 Mustang GT | | Join Date: Jan 2007 Location: Jersey Age: 25 | | | Re: Little Rough Idle at Cold Start Is it violent shaking when you first start it? Thats one of the first signs of a failing headgasket. But if it is just a slight misfire, I would swap out the plugs, fuel filter, etc. |
04-22-08, 06:42 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Little Rough Idle at Cold Start Probably due for plugs & wires. Stick with A/C Delco |
04-23-08, 01:56 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger | | Join Date: May 2004 Location: Atlanta, GA Age: 27 | | | Re: Little Rough Idle at Cold Start get a hydrocarbon test done on the coolant, let you know if there's a headgasket problem, I had the same symptom on my 98 ETC for over a year before I popped the head... |
04-23-08, 10:33 PM
| | Cadillac Owners Member | | | | | Re: Little Rough Idle at Cold Start Might be intake manifold plenum gasket. They can crack and leak causing rough idle and poor mileage.
Don't rule out condensation in gas tank. Especially when tank is low and during humid weather. |
04-23-08, 10:35 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Jan 2008 Location: ORL. FLORIDA | | | Re: Little Rough Idle at Cold Start i am having a similar problem. a shaking thats pretty bad,but then it goes away.it has always had a little rough idle,i changed the iat motor ? helped for like a week, now it shakes really bad when started and when idle at red lights. when i mash the gas it bogs down,backfires motor whines ,not revivng high and then starts to go.under normal acceleration it just has a little hesitation. please help i have a 500 mile road trip in a day |
06-24-08, 12:14 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac Deville '98 | | Join Date: Jun 2008 Location: Chicago | | | Re: Little Rough Idle at Cold Start I have pretty much the same problem. I just bought a 98 Deville 102.000 mi and when i start in the morning, idle fluctuates in between 1000 rpm and 850 rpm (it doesn't sound too bad) until it warms up. When is warm, it settles at 650/ 625. I do get poor mileage 12 mpg in the city and 16-17 on the highway.
i changed the air filter and checked the FPR (no visible leaks). How can i clean the manifold? Is it a do it by yourself thing? I still have my old Caddy (94 Deville- 220.000 mi) and i never had these kind of problems,,, or code P0741 witch i have on the 98.
I'm new on the forum and i don't know how to open a thread.
please help! |
06-24-08, 09:13 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Little Rough Idle at Cold Start Open a new thread with the "NEW THREAD" button at the top left of the page. Don't worry about cleaning the manifold. Clean the TB. Do a search for how to do it. There may be a tutorial in the Tech Tips section. |
06-24-08, 09:53 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Little Rough Idle at Cold Start Bigsnow.......No "plenum" on pre-2000. What's your car, engine, year, mileage ???
Every question in posts #1,5,6, and 7 is answered in here and Northstar performance. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
