| 94 STS- Changed FPR and Weird Things Happened My '94 STS had been starting hard when cold, and I have been through this before with it. Had the FPR changed- last time by the dealer (thanks $300). Changed it on my wife's '98- was easy. So I start in on the '94 this morning. Set up a bit different than the '98. The FPR goes in from below instead of from the top like the '98 and newer. Okay, so I pop the black frame that holds it in, and also hold what appear to be something to do with the coil and spark? (Am I correct?). Anyway, I actually have no problem getting the FPR in. Snaps into place. Of course, I had no fuel pressure, only a couple drops dribbled out...hook up the fuel line and it seems everything is ready to go back together
So, after I replaced the cover and everything was back together (it said don't start the motor w/o the beauty cover in place), I start the car. It immediately races to 3500 rpm! I shut it off. Then start it once more. Again, races to 3500 rpm, kinda stumbling. Shut it off again. I let it sit a minute then try a third time. This time it caught smoothly, and the rpm started climbing but leveled off at 1250. And it stayed there. It was running smooth, but it was idling really high at that rpm. I went through the diag codes but nothing, except the "service engine soon" light came on. So, did I do something wrong, or did I fix one problem and uncover another? BTW, I let it idle about a minute or so at 1250 and when I shut it off the motor was blow smoke around the engine bay. That didn't seem right either. Have 160K on her with no major problems until it the hard cold starts... |
